Hi.
Just bought a very nice Induma mill fitted with an Anilam 1100m control system.
The machine have not been used for a few years, so when i started it up, the BIOS battery was flat. I managed to desolder the clock-chip from the board, dremel two holes in the side of the chip, and solder in to wires to attach an external battery. All done, the machine started straight up into the Anilam CNC software.
I now i have two problems.
First problem; i can not for the life of me, get the servos working.
I have tried to jog the machine manually, and there is no response. I get a message that says: "Error: Servos are off.".
If i load a program and try to run it, i get the message: "Servos are off, cannot execute!"
I can not find any settings in the software that should cause this.
I have tried to measure the power supplies, but the wiring diagram i have does not show what voltages i should expect to find.
The second problem i have is that i can not get the spindle to run from the CNC control.
If i flip the "spindle manual/auto" button to manual, i can push "spndle fwd" or "spindle rwd" on the display. The corresponding relay clicks, but it does not for some reason activate the contactor. If i manually trigger the contactor, the spindle starts.
I have also here tried to measure the voltage supply to the contactor, but have a hard time tracing exactly where the power should be coming from.
There is a diagnostics system on the mill, but i need the floppy drive to run the diagnostics software, which i do not have.
Should i spent time trying to get the Anilam system working or should i go on with retrofitting a newer control system?
The machine is in very good condition, so it would be nice to get it back to it's former glory.
A few images attached![]()
