Is it possible to us a flash card as a buffer when you work with a Star machine but with the channel n°2. I don't have enough place to save the programe on channel 2. I have a Fanuc system.
Any idea?
Thanks for your help
Any idea?
You can drive your program off the memory card if you save it as a subprogram and use m198. You will probably need to change a parameter to make it work. Check your yellow fanuc books on m198
