603,970 active members*
2,980 visitors online*
Results 1 to 6 of 6
Hybrid View
    Floating Head Improvements?
    Homebuilt Plasma machine
    THC300 Torch Height Control
    Hypertherm Powermax 1000 Plasma with machine Torch.
    Finecut Consumables used for thin sheet.
    Sheetcam programming software
    Is there anything I can do to improve my floating head setup.
    I mainly cut 1.5mm (16swg) stainless steel with finecut consumables and I get problems with the floating head flexing the sheet too much before it trips the microswitch.
    Even after the head has risen to its 2mm piercing height the nozzle is still touching the sheet and it sometimes burns the nozzle out.
    Today I burned two nozzles out within 5 minutes of each other, not cheap at £6 a throw
    It is fine when it pierces over a slat and the thin sheet does not flex.
    I have the offset set in Sheetcam and I have had to resort to raising the offset by an extra .5mm which is not ideal.
    I have seen some 'Non-contact' devices to sense the initial height, are these any good?
    Any other ideas much appreciated
    Andy
    Jul 2005
    2415
    Quote Originally Posted by Normsthename View Post
    Andy
    1. The non-contact IHS solutions are expensive and need constant tweeking based on the material. There are ways to measure distance with infrared (like a camera does) or via capacitance but both are costly or inaccurate (or both) it's hard to resolve variances of less than + - .020 across different surfaces and under varying conditions. At the very least you would need to "calibrate" the sensor for a given sheet of material. While in your case, where you cut a lot of the same type, that might not be too bad, but most shops cut a varity of material types and with different surfaces.
    2. I cut a lot of 16ga material and to get around the deformation problem I added an adjustable "bias" spring that counter balances the weight of the torch so now I can adjust to provide a feather touch on thin material. It does require you keep the slides of the floating holder clean and lubed. Problem solved. It also helps to have the cut grid spacing tighter so it has more support.
    3. The addition of a an ohmic sensor tip would appear to be the solution but it has two major disadvantages:
    a. It can malfunction on dirty , rusted, oily or painted material. If it does you can cause damage to the torch. To prevent that you have to have torque feedback on the torch motor. On the THC300 system where the Z motor is the THC lifter motor, measuring the motor current accurately (on a stepper especially) and feeding it back to the control software (MACH) would cost a lot of electronics.
    b. The typical ohmic sensor uses the material as one side of the conductor. Since it is at Plasma (dirty) ground, the circuit then connects the noise of the plasma ground (at logic levels) over to the control electronics. The THC300 is isolated from the logic side to block conducted noise and an ohmic sensor not hooked up properly would cancel the inherent isolation of the THC. In short it could result in erratic operation all the way to damage to the THC electronics.
    For a few thousand bucks you can have a stand alone THC solution that has either ohmic or torque feedback sensing but you will lose the ability to use the "lifter" for any Z level control. The bias spring is a lot cheaper and works well.
    TOM caudle
    www.CandCNC.com
    Jul 2006
    1062
    Hi Andy, I just took delivery of a CDE THC controller...Preliminary tests without having the torch live shows great promise....yet to be seen how it copes with actual use...I'll post back once it's actually cutting stuff.
    URL for manual here
    Keith
    Thanks Tom
    I did think about adding a spring to counterbalance the weight of the torch and holder
    URL for manual here
    Kipper, I will be very interested in seeing your setup
    Andy
    May 2010
    Hello, I'm starting my cnc for plasma I wonder if you could send me pictures about your bias spring system, I can't even figure it out, besides english is not my first language, [email protected]
    Thank you!
    Feb 2006
    1260
    Quote Originally Posted by Serafin View Post
    Thank you!
    Attach spring(s) that has adjustable tension to almost off set the weight of your floating head.
    Then the weight of the floating head doesn't deflect thin material. At least not as much.
    If your torch head + floating head assembly weighs 10# Put enough tension on a spring, pulling up on the floating head to almost balance it out.
    Hope this helps some
    If it works.....Don't fix it!
  1. Floating Z Head
    By tulsaturbo in forum Mach Plasma / Laser
    Last Post: 03-18-2021, 11:55 PM
  2. Z Floating Head Question(s)
    By needonemoretool in forum Waterjet General Topics
    Last Post: 03-29-2010, 05:40 PM
  3. Floating head switch
    By millman52 in forum Waterjet General Topics
    Last Post: 06-15-2009, 02:17 AM
  4. Floating Tap Head - Advice Please
    By UKRobotics in forum Uncategorised MetalWorking Machines
    Last Post: 10-24-2007, 02:03 AM
  5. Floating Head Switch?
    By Redline in forum Waterjet General Topics
    Last Post: 09-18-2006, 02:21 PM
