I wanted to give back to the community and help some of you out who are running flood coolant. I have run flood now for about 5 years on the little G0704 and have tried about 3 or 4 different coolants. From rustlick, Lennox, coolmist, and now I have finally fell in love with a coolant that does everything I could ask for.
My list of complaints of bad flood coolants were the following:
1- goes bad, stinks, gets rank, growth, health issues, skin irritation
2- leaves sticky residue
3- stains parts
4- peels paint
5- rusts table, dovetails, vises
6- poor part finish
7- hard on plastics making them brittle
8- washes way oil off and mixes with it
After replacing several plastic hoses and air lines that continuously cracked while using coolmist as a flood, I decided it was time for a change. I did alot of reading and calling around and finally settled on Koolrite 2290. It's affordable at about $35/gallon concentrate with free shipping, the fact that it's available in gallon sizes is a plus for small machines with small flood sumps.
So I ordered it figuring it can't be worse than any of the others I tried before. First thing, I completely cleaned the coolant system to remove all traces of the coolmist, replaced filters etc. Then I mixed the koolrite 2290, I mixed my first batch at 9oz coolant poured into just under a gallon of water, and topped up with water, shook and Poured into my tank. Repeated 4 times for my 4 gallon capacity tank. It's a light milky amber color with a pleasant smell. Not as fun looking as the pretty green coolmist, but oh well, function over form here right!!
So I loaded up my first part post coolant switch and let her rip. First thing I noticed was how much quieter the machine was cutting. Had to double check my feeds and speeds because it was vastly different audibly. All was as programmed so it's the coolant I thought but shrugged it off. Next op was high speed deep peck drilling, usually a stringy mess.. not this time, beautiful small chips, no strings..hmm OK interesting.. down around the 2" deep mark there was no screeching on the retract.. that was nice I thought. So with drilling done, I moved on to the next op, perimeter adaptive roughing. Wow, what a difference, I actually stopped after the first 30 seconds to reprogram with a more aggressive cut because it was so smooth and a long job i figured I might save some time with a larger cutter. So I moved up to a 1/2" 3 flute 2" loc carbide endmill from online carbide (love his tooling!). Cut my op time almost in half running 45ipm with a 15% stepover, .75" doc at 5000rpm, .003" chip per tooth. Machine cut beautifully, quiet, smooth with no chatter. Impressive for this little machine with that size cutter from my experience. On to the finishing op..... Contouring at 1.5" doc.. never a pretty thing usually on such a small machine. When it completed, I opened the doors and hosed the part of and hit it with air to dry it before pulling it from the vise. I was astonished.. Never ever has this machine made such nice part finishes.. I don't mean smooth, I mean mirror finish on a side milling op especially at any depth over .5".
Pictures below.. absolutely blown away with the performance of this coolant and highly recommend it. It has been about 5 weeks now with the coolant in the tank and it is perfect, no smell or growth, it doesn't mix with tramp oil or wash it away. No skin irritation, zero rust, even when the vise was removed after 3 weeks of being bolted to the table. Amazing!! Can't say enough for this stuff, but I will let the parts speak for the performance!!
Some of these are after roughing operations which are still better than the same tools used previously for finishing passes. Blown away!! Hope this helps some of you!!
Chris
