603,794 active members*
4,595 visitors online*
    Jul 2016
    25
    Flycutting Aluminum
    Hello,
    I am attempting to use a flycutter to face aluminum. I purchased this set of flycutters and would like to use the largest one, 1 3/8" diameter. I will be facing cast aluminum and 3003 aluminum with a Tormach 770. Are the lathe tools pictured on the product page ground to the correct shape for my application? Also, could someone recommend some feeds, speeds, and DOC?
    Jun 2010
    4260
    Re: Flycutting Aluminum
    It should work OK. You will need to round the cutting edge to get a good finish.
    I (strongly) recommend you start with very shallow cuts and limited RPM. Feed is not so much of a problem.
    Say 1000 rpm, 100 mm/min, and a cut of 0.05 mm depth. With this you will soon find out the limits of your machine - and how much it flexes.
    Cheers
    Roger
  1. Flycutting with a router
    By ssozonoff in forum CNC Tooling
    Last Post: 01-22-2009, 09:57 PM
  2. Flycutting: New Insert
    By tikka308 in forum Benchtop Machines
    Last Post: 07-03-2008, 01:29 AM
  3. Taig + Flycutting
    By tikka308 in forum Taig Mills / Lathes
    Last Post: 07-24-2007, 08:57 PM
  4. Flycutting on a Sieg X1
    By itsme in forum Benchtop Machines
    Last Post: 08-02-2006, 09:49 AM
  5. How to hold-down for flycutting?
    By Swami in forum MetalWork Discussion
    Last Post: 11-25-2004, 03:19 AM
