588,293 active members*
4,899 visitors online*
IndustryArena Forum > CAM Software > GibbsCAM > forced tool change
Results 1 to 4 of 4
    Sep 2014
    forced tool change
    Our shop hired a new programer that SUCKS. He is using Gibbscam, and i am not familiar with it. I know Mastercam. The problem i have is when you are using 1 tool to cut multiple features on one part Gibbscam bundles all the code together into 1 sequence. On Mastercam i can tell it to FORCE TOOL CHANGE and i have a new sequence for every feature i want to cut. This allows me to skip and jump around the program and dial in features with out waisting time. What is this called on Gibbscam and how do i apply this function to a program?
    Aug 2006
    142
    Re: forced tool change
    It's not Gibbs so much as it is the post he's using. Have your Gibbs dealer alter the post to put out a full start-up stanza at the beginning of each operation. This may become a problem when working with controllers like 6M's where memory is short.
    "Teach the ignorant, care for the dumb, punish the stupid."
    Jan 2005
    15362
    Quote Originally Posted by eucjosh View Post
    You don't have to force a tool change,unless you are changing the tool, & then that is a simple Tool Call, you just have to do the operation that you want to skip around, if it is the same tool it will do what you are programming it to do, no matter what you want it to do, it's all in the selected operation, if you have 10 different features you want to adjust on, then do the operation for each feature, & then you can adjust each one
    Mactec54
    Jun 2015
    Create a new tool tile with the exact same information as the original tool. Give it a Tool ID and CRC / Length Offset of the same tool.
    When you alternate between the original tool and the 'tool id' tool, it will force a tool change.
  1. How to change Tool change position(About MAZATROL T1 control)
    By liushuixingyun in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-07-2014, 01:33 AM
  2. forced to run coolant
    By waligtr in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-28-2013, 06:06 PM
  3. Forced Flywheel
    By nolage in forum Benchtop Machines
    Last Post: 03-13-2012, 05:48 PM
  4. forced output
    By SCOOT90 in forum Post Processors
    Last Post: 02-10-2011, 03:26 PM
  5. Forced to learn Mastercam X4
    By CNC Newb in forum Mastercam
    Last Post: 01-01-2010, 01:36 AM
