603,946 active members*
2,386 visitors online*
IndustryArena Forum > Mechanical Engineering > Mechanical Calculations/Engineering Design > Formula for B axis rotation on machining centre?
    Jul 2008
    22
    Can anyone tell me the formula for X and Z co-ordinates when you rotate the B-Axis around the centre of a horizontal machining centre and the you have a part or fixture which is sitting at z200.
    Assume that the part has been loaded at X 0, Y 0 and the hole is on Y0.
    eg. Say I want to drill a hole at 45° on a diameter.
    My component is Z200.0 from the centre of the table(centre of rotation).
    I rotate the B axis 45° around the centre of the table .
    What would my x and z figures be.
    Aug 2007
    147
    I'm guessing you have a cylindrical part clamped to a tombstone, and the cylinder is oriented vertically, parallel to the Y-axis? Also, you want X-zero to be the center of the cylinder?
    Z-zero = cos(B) * (200.0 - R) + R
    X-zero = sin(B) * (200.0 - R)
    B = B-axis rotation in degrees
    R = Radius of the workpiece
    Different formulas if you're cutting flat workpieces.
    -Sol
    Glacern Machine Tools
    Jun 2008
    20
    Hello fitzpatrick,
    you can download and use CNCOffsetCalculator for calculation of the offsets on horizontal machining centres - it gives you the X,Y,Z coordinates (if you know exactly the position of the workpiece) or it generates a CNC code (G10 code or system var) and the machine will calculate the offsets when it runs.
    You can download the program from cncplusplus.com
    Regards,
    Zdenek
  1. Need to purchase 3AXIS Machining Centre
    By camgp in forum MetalWork Discussion
    Last Post: 05-17-2009, 01:10 PM
  2. 5 Axis Machining and 6 Axes Turning Centre available
    By syamin in forum News Announcements
    Last Post: 02-16-2009, 01:25 AM
  3. Problem on CNC machining centre (VMC)
    By sunilsawant123 in forum CNC Machining Centers
    Last Post: 10-11-2007, 04:53 AM
  4. Low cost machining centre retrofit
    By motordude in forum Uncategorised MetalWorking Machines
    Last Post: 01-07-2005, 08:32 AM
  5. Anyone got any vids/pics of a cnc machining centre with.......
    By Darc in forum Uncategorised MetalWorking Machines
    Last Post: 11-28-2004, 10:06 AM
