603,936 active members*
2,792 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Forum For DIY CNC Router Machines ... Is This the Better Forum?
Results 1 to 1 of 1
    Oct 2010
    15
    Which Forum(s) are better for DIY CNC Router Projects? I use the MASSO G3 Touch with a BULLMAN's latest CNC Router Mechanical Kit,w/ HY02D211B VFD 2.2kW Spindle, X-Y/B (3) Integrated Servo Axis, Z Integrated Hybrid Servo-Stepper Axis.
    I'm just started 'check-out' and 'setup' for commissioning the CNC Router.
    To start, my main focus is setting up the HY02D211B VFD Drive. Interfacing E-Stop String into HY VFD is kind'a 'Trick'! I am planning to re-program function RST (STOP) and SPH (RUN). I am unsure to use HY 'STOP' or 'E-STOP' function for System E-Stop?
    Are there forums dedicated to MASSO G3 Touch, HY VFD Spindle & Axis drives?
    Thanks for your input.
    Cheers, Billy
    Re: Forum For DIY CNC Router Machines ... Is This the Better Forum?
    In my opinion, CNCzone is better for DIY CNC Router Projects.
