603,384 active members*
3,086 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > found xy table... want to make into wood router
Results 1 to 7 of 7
    Jun 2010
    This seems like a pretty nice xy table, I think it came from an industrial sewing machine. The threads don't seem to be ACME, any guesses?
    It has about 10.5x10.5 of motion. I think the motors (not shown) are 450 oz unipolar steppers.
    I'm considering mounting it to replace the Y and Z axis on top of a Solsylva table with the the goal of routing dimensional lumber or making small parts out of plywood/mdf.
    My motivation is purely for hobby purposes. Suggestions welcome.
    Attached Thumbnails Attached Thumbnails Screen shot 2010-06-17 at 10.30.53 PM.png   Screen shot 2010-06-17 at 10.31.48 PM.png
    Apr 2009
    5516
    Looks like multi-start rolled acme...
    Jun 2010
    As best I can tell, it is 1 start. Regardless, I think I have a pretty solid plan for it.Embedded Acquisition Systems shows a nice example of mounting a wood router to a micromill z-axis. I'm planning to build an enclosure around it, swap the steppers with smaller Xylotex steppers then add the Harbor Freight z-axis and spindle.
    Jun 2010
    Here is a pic of how they mounted a wood router.
    Attached Thumbnails Attached Thumbnails Screen shot 2010-06-20 at 9.23.08 AM.png
    Jun 2005
    176
    I have scrounged my Y and Z axis off an old blueprint reducing machine so your hardware looks very doable.
    Have you checked the nuts for backlash? If they've done a few hundred miles on an industrial sewing machine they might be a tad worn.
    It would be a shame to build a machine around hese parts if they're worn.
    The parts that I obtained had been used extensively but with extremely light mechanical loads, just moving lenses and stuff and subsequently have little actual wear and very minimal backlash.
    Jun 2010
    One of the nuts has something hanging out of it. Not sure if I should leave it alone or dig in to see what's going on. Probably the latter.
    I stuck a dial indicator on it and am trying to measure backlash by hand. No conclusions yet, other than it seems pretty smooth, I can make it go to any number I want on the thousandths of inch scale. I think I can simulate steps by making a mark on the timing gear then moving it forward a few ticks then back to its original position.
    May 2007
    380
    I would be willing to bet the screw is multi-start. It is hart to tell if you can't see the end of the screw. The nuts are probably anti-backlash. If the nut has a small spring wrapped around one end, that's what it is.
    John
  1. CNC router table to cut mostly foam and some light wood.
    By rcbamm in forum DIY CNC Router Table Machines
    Last Post: 10-24-2011, 06:13 AM
  2. MDF vs Plywood and wood vs metal Router table
    By bevins in forum Open Source CNC Machine Designs
    Last Post: 10-09-2010, 07:20 PM
  3. Anyone make a plasma/router table?
    By bamwa in forum Waterjet General Topics
    Last Post: 01-13-2009, 07:49 AM
  4. Can a wood router make paint stencils?
    By samualt in forum DIY CNC Router Table Machines
    Last Post: 05-10-2004, 06:46 AM
