is fourth axis indexing done by rotating the a axis by hand or is it done by motors? ie when the xyz axis are moving along simultaneously and they reach a point where the work piece needs to be rotated on the A axis does the xyz pause and the a axis motor comes on to rotate the work and then the xyz motion resumes, or does the xyz pause while the a axis is rotated by hand?
thanks
