High Pressure Laminate
I'd say run it like Aluminum, but really have no idea. lol.
CNC Bits for Cutting HPL Laminate
Feeds&speeds for delrin seem to work for HPL.
Thanks for the advice
Greets paede
I would expect on the Tormach, you probably want to run both spindle and feeds about as fast as the machine will allow. I cut many plastics at well over 100 IPM. You might also find a straight-flute carbide endmill or carbide router bit will work better than a nromal endmill, and have less tendency to chip the edges.
Regards,
Ray L.
