603,330 active members*
3,020 visitors online*
IndustryArena Forum > CAM Software > Autodesk CAM > Autodesk Post Processors > Fusion 360 for mill turn mazak lathe.
Hybrid View
    Oct 2016
    106
    Does anyone have a post processor for fusion 360 for mazak lathe with milling like sqt250 m? I tried post processor for integrex and the code is ok but I have to get rid of all b axis stuff and other codes. Any help modifying a post much appreciated.
    Regards
    Tomasz
    Sent from my D5803 using Tapatalk
    Jun 2008
    1838
    Re: Fusion 360 for mill turn mazak lathe.
    Tomazs
    Can you put a copy of your post processor in a Zip file and upload it so someone can have a look at it, also Zip up some good code that can be used as an example.
    Regards
    Rob
    Oct 2016
    106
    Quote Originally Posted by The Engine Guy View Post
    Tomazs
    Regards
    Rob
    working programme.
    (****MILLING MODE****)
    (18 JUL 22 - 09:59)
    (TIME 0:0:26)
    G53M302(MAIN CHUCK)
    G17 (X&Y PLANE)
    G21 (METRIC)
    G40 (COMP CANCEL)
    G90 (ABSOLUTE)
    M5
    G28 U0 V0
    G28 W0
    M205
    M212
    M202
    M200 (MILLING MODE)
    G28 H0
    N10 M1
    (FINISH PASS)
    (DUMMY FLAT)
    (EFFECTIVE DIAMETER 10.)
    (STOCK AMOUNT 0.)
    T0101
    M212
    G0 C0.
    G98 G97 S2546 M203
    G17 UH
    M211
    G12.1
    G0 Z10.
    G0 X5. Y40. M8
    G0 Z1.
    G1 Z-20. F3820
    G3 X0. Y45. I-5. J0. F764
    G3 X-45. Y0. J-45.
    G3 X0. Y-45. I45.
    G3 X45. Y0. J45.
    G3 X0. Y45. I-45.
    G3 X-5. Y40. J-5.
    G0 Z10.
    G13.1
    M205 M8
    G28 U0
    G28 W0 V0
    M212
    M202
    M30
