603,940 active members*
2,308 visitors online*
IndustryArena Forum > CAM Software > Autodesk CAM > Fusion360 CAM NC Code - create a toolpath from an imported 3D Nurb spline??
    Sep 2005
    29
    Can Fusion360 CAM - create a toolpath from an imported 3D Nurb spline??
    Hello, I used to have a small machine tool business and used Surfcam for programming my cnc equipment. I have been helping a friend with creating a few nc programs until he acquires his own programming software such as Fusion360. I have been creating a few tool paths for him by importing his igs file of a 3d Nurb Spline and following it as a 3d contour to generate the xyz NC code. I also offset it in Z based on the ball end mill he specifies.
    I do not have Fusion360 nor used it but have recommended to my friend Fusion360 for tool path creation, I like what have seen so far about it.
    Can anyone confirm that Fusion360 can make nc code from an imported iges of a 3D Nurb Spline like what I can with my Surfcam?
    If anyone cares to create a sample code file that would be great, I would be interested to know the process on how its how its done in Fusion but more importantly that it can actually be done.
    Attached is a sample 3D Nurb Spline and the NC Code that I generated in Surfcam with a a 10mm Ball tool.
    CNCZone has always been a wealth of information for me, thank you to all contributors. Robert
    Re: Fusion360 CAM NC Code - create a toolpath from an imported 3D Nurb spline??
    I use fusion's trace command in this case.
  1. Replies: 3
    Last Post: 12-10-2024, 08:43 AM
  2. CAM software to choose toolpath for g-code
    By piro00 in forum Uncategorised CAM Discussion
    Last Post: 06-18-2021, 11:46 AM
  3. convert nurb spline to arc?
    By Joesph Jackman in forum Mastercam
    Last Post: 02-27-2012, 02:00 AM
  4. Can flexisign create G code toolpath
    By kputer in forum Signmaking Topics
    Last Post: 06-24-2011, 07:33 PM
  5. Create Stock Around Imported Solids
    By thebowman in forum Esprit
    Last Post: 01-04-2010, 07:16 AM
