603,970 active members*
2,969 visitors online*
IndustryArena Forum > CAD Software > Autodesk > FUSION360 W/FADAL ISSUES GOING HOME AFTER END OF PROGRAM
    Jul 2023
    6
    With a Fadal 6030
    When program is finished it wants to go to the work offset '0' before going to machine home.
    The concern is the tool hitting any fixtures along the way.
    It looks like the g28 code is telling it to jog around to the 0 position of XYZ of the work offset, then gradually make it's way to the machine home position.
    What I'd like it to do is:
    Program complete
    Rapid Z to safe location
    Turn off coolant and spindle
    Then work it's way back to XYZ 0 of the home position.
    (See code below) I've tried adding a couple of inches to the N85 Z position, but this causes Z to over travel and hit the limits when it finally makes it to 0 (as if it's adding those inches to the final Z position.
    I've tried taking out 628, changing G90 to G91, changing the code to G0Z0H0,G0X0Y0, AND G91 H0 ZO.
    E0 X0. Y0. I've tried all sorts of options, but nothing gets Z out of the way.
    Once this is finally resolved, is there a way to add this to all programs, so that it doesn't have to be manually inputted for each program?
    Thanks in advance for your help.
    O1001
    (MACHINE)
    ( VENDOR: AUTODESK)
    ( MODEL: GENERIC 3-AXIS)
    ( DESCRIPTION: THIS MACHINE HAS XY AXIS ON THE TABLE AND Z AXIS ON THE HEAD)
    (T1 D=0.25 CR=0. TAPER=90DEG - ZMIN=-0.64 - SPOT DRILL)
    N10 G90 G94 G17
    N15 G20
    N20 G28 G91 Z0.
    N25 G90
    (DRILL2)
    N30 T1 M6
    N35 S1527.9 M3
    N40 G4 P118
    N45 G90 G94 G17
    N50 M8
    N55 G0 E1 X-5.4835 Y2.1742
    N60 G43 Z0.6 H1
    N65 Z0.2
    N70 G98 G81 X-5.4835 Y2.1742 Z-0.64 R0+0.16 F3.06
    N75 X-6.4835
    N80 G80
    N85 Z0.6
    N90 M9
    N95 G28 G91 Z0.
    N100 G90
    N105 G53 X0. Y0.
    N110 M30
    Nov 2013
    5414
    Re: FUSION360 W/FADAL ISSUES GOING HOME AFTER END OF PROGRAM
    I use Fusion but I use 'Clearance Hieght' in the post settings. That means the machine lifts up and out of the way when the part is finished, and that location is programmed
    as part of the tool path. In my case I usually choose 50mm above the topmost of the part and or workholding.
    You can use g28, g30....and they will eventually retract to machine home, but can and sometimes do take an intermediary step back 'into the danger zone'
    If I'm not mistaken you can change that intemediary step, it is put ther by the post. If you edit the post you can change that location and thereafter all toolpaths will retract via the intermediate point
    you have specified in the post..
    Craig
    Jul 2023
    6
    I just realized I put this post in the CAD section and not the CAM section.
    I just moved the post over there, to hopefully get some solutions to resolve the issue.
    I have tried utilizing the clearance height however it still moves back over to the work offset before going to the machine home X0Y0Z0
    Through trial and error, the G28 is what initializes that. Regarding your "intermediary step", even though I understand what you mean, I do not know where that is in the program, nor do I know how to find it within the software - assuming it is somewhere in the "post processing" section.
