588,657 active members*
6,066 visitors online*
Results 1 to 1 of 1
    Jul 2013
    g code - invert X axis after one pass...
    i have problem with my g code file (file incl. as attachement)
    both my pycam and mastercam generated g codes looks ok when simulated but when i run engraving after one contour pass mach3 switch to inverted axis (scale -1.0) and continue engraving miror reversed contour. this problem is maybe trivial but since i am new with cnc it ia a big problem for me...
    Attached Files Attached Files
  1. Invert for HSd spindle..really need help.
    By happytriger2000 in forum Mitsubishi controls
    Last Post: 06-09-2012, 08:44 AM
  2. Z axis goes to rapid height after each pass
    By Sonicmook56 in forum Uncategorised CAM Discussion
    Last Post: 04-01-2011, 04:18 PM
  3. Invert 12V to -12V
    By rainman in forum MetalWork Discussion
    Last Post: 02-15-2007, 04:43 PM
  4. Invert code
    By JW Peters in forum G-Code Programing
    Last Post: 03-09-2006, 04:06 PM
  5. Table setup - Axis invert
    By horse in forum Uncategorised CAM Discussion
    Last Post: 02-28-2006, 03:45 PM
