603,409 active members*
3,274 visitors online*
Results 1 to 8 of 8
    Mar 2004
    7
    Unhappy G-Code letters What are the definitions?
    I am currently setting up a machine and having problems. I am looking at the G-code after posting, how do I find the definitions of each of the letter codes? Example what is SP,SF and PA? Is there a place to find these definitions?
    Sep 2003
    552
    SP,SF and PA could be your problem. Most G code programming is one letter followed by a numeric value.
    Example:
    N010 M03 S300
    N010=block number
    M03=spindle forward misc. function
    S300=spindle speed of 300
    Darek
    Mar 2004
    120
    Hi CADkathy,
    here is a link to general G-code definitions... http://www.linuxcnc.org/handbook/gcode/g-code.html
    As I understand it, SP,Sf or PA are NOT standard RS274D G-code.
    Hope this helps... a bit
    Gary
    embrace enthusiasm to accomplish the task
    Gary Davies... www.durhamrobotics.com
    Jan 2004
    62
    It might help to identify what control you are using. Some of the PC based or other controls may have unique designations.
    Jul 2004
    3
    What is your CAD program? What is your machine control? If you have a programming manual for the machine, it will tell you all you need to know. Otherwise give some more info here and you'll get the help you need.
    Matrixman
    Jun 2004
    38
    Ultimate G-CODE Reference
    Complete G-Code reference from the people that had a bit of a hand in designing it. NIST... :cheers:
    Attached Files Attached Files
    Mar 2004
    7
    Talking Thanks for the Leads!
    With the information y'all (Yes it has been a long time since I moved South) sent, I was able to contact my software provider and determine the post processor the machine manufacturer suggested I use was incorrect. I am now using another post and my machine is cruising.
    Thanks again! :banana:
    Jun 2004
    67
    Kathy,
    Just for the record, SP and SF and PA represent "Select Pen" / "Set Force" / "Plot Absolute" in Hewlett-Packard's proprietary 2D pen-plotter language HP-GL. They are adopted also into certain versions of RML and CAMM-GL used with Roland 3D micro-mills.
    Regards, Terrence
  1. parametric programming
    By Karl_T in forum CamSoft Products
    Last Post: 05-24-2005, 08:58 PM
  2. Autocad fonts (letters) to .dxf files
    By fiedd in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-09-2005, 12:54 AM
  3. I need sample G code program
    By bunalmis in forum G-Code Programing
    Last Post: 08-24-2004, 09:50 AM
