my control board is is the latest from machmotion, the program is Mach 3 what do I save the post process as ...I use Dolphin Cad/Cam, it saves to mach 3 but my machmotion not reading it or showing the drawing Machmotion tech says it in the post process.....so what should I save it in ..there is G-code examples on the machmotion.com if that helps
Thank You, Kevin
