588,585 active members*
13,576 visitors online*
Page 1 of 2 12
Results 1 to 20 of 23
    Jun 2004
    822
    G0704 Motor Problem
    I finally tried to use my G0704 tonight (really the first time since I bought it other than the break-in). It seemed to be doing OK except I thought it kind of smelled - couldn't really tell where it was coming from. Well, about 10 minutes into my work, I heard the RPMs vary a little, then a pop and it tripped the surge protector which shut the whole works down.
    It will turn back on and the motor will spin but there seems to be too much noise and fireworks. Here is a short video I made of what it's doing now. The view is from the top of the motor down - its really interesting after about 12 seconds when you can hear the RPM varying and some smoke and noises that it probably shouldn't be making. Any ideas on what I should do?
    [nomedia="http://www.youtube.com/watch?v=7JdrL8MFrWs"]YouTube - 00000[/nomedia]
    Jun 2004
    822
    I don't think the brushes should look like this either.
    Mar 2007
    2083
    I think you need a new armature
    is the machine still under warranty ?
    if not, search for motor armature at littlemachineshop.com for example
    for a picture of what it should look like
    if copper segments is burnt away at the gaps between them
    the armature will need replacing
    to test the armature windings when removed from the motor
    connect an ac voltage ( 6v or so ) across the commutator
    and measure the voltage between adjacent segments should be the same
    shorted turns will cause variations in the readings
    John
    Jun 2004
    822
    Yeah, it's still under warranty. At first I thought I may just try to clean it up on the lathe:
    But looking further, it looks like some of the windings may be damaged.
    Guess I will be calling Grizzly on Monday to see if I can get another motor.
    Mar 2007
    2083
    yes a phone call to Grizzly is your first step
    in the first picture you can see the gap between some of the segments are wider than they should be
    and in the second picture one burnt winding
    no testing required with this one
    the next question is does the speed control still work
    with my minilathe I used a 100w tungsten filament bulb as a dummy load
    while testing the speed control
    good luck
    John
    Jun 2004
    822
    Hmmm... the speed controller seemed to work. It is wired directly into my BOB and it still turned it on and off and changed speed.
    Dec 2004
    1865
    Don't feel bad a friend of mine had the same thing happen to his machine.
    Along with several other problems he has had to have Grizzly make 4 shipments to replace the dead crap with working crap.
    It will finally work in the end.
    Mike
    Warning: DIY CNC may cause extreme hair loss due to you pulling your hair out.
    Jun 2004
    822
    Well, I talked to Grizzly this morning. They want me to inspect the controller prior to putting in the order for the motor to make sure it isn't damaged. I'm not sure what to look for other than 'something not looking right'. It also doesn't sound like they have any motors anyway so I guess I'm stuck for the time being.
    Jun 2004
    822
    Are the stock motors 90VDC and 1800 RPM? If so, I wonder if this would be a decent upgrade:
    Automation Direct Motor
    Dec 2009
    1416
    90V is correct I believe but not sure about the RPM. Looks like a nice motor though. Bit spendy.
    ETA: The shaft is a good bit fatter, and the mounting holes are on a larger diameter too than even the 800watt motor on the PM25. The outside diameter is larger as well. Would take some work to get it mounted.
    Jun 2004
    822
    Ah yeah, it's a 5/8 shaft. Do you know what the stock one is? I will keep looking.
    Dec 2009
    1416
    Quote Originally Posted by mrcodewiz View Post
    Shaft on my 800watt is 12mm, just a hair under. That may be bigger still than the 600watt. I don't have the plans in hand that had the G0704 motor in them. I can take a look tonight.
    CNC: Making incorrect parts and breaking stuff, faster and with greater precision.
    Jun 2004
    822
    I guess if I go with the belt conversion the shaft size won't really matter. It is pretty expensive though.
    Jun 2004
    822
    Would a 2HP(ish) 90V treadmill motor be a suitable replacement? It seems like most of them have much higher RPMS (4000+).
    the stock motor is 5000 rpm with a 10 mm shaft.
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
    I just picked up one from this Ebay seller.
    motor items - Get great deals on Incline Motors, Treadmill Motor Chokes items on eBay Stores!
    They rate them at 2 - 2.75 HP but that's at 180 VDC ish.
    He has a photo of his motors label and you can see that they run around 1.3-1.5 HP continous at 90-100 VDC
    depending on motor which is a perfect size for this mill.
    Gonna take some mods and fan work to get it to fit.
    Hoss
  17. #17
    Jun 2004
    822
    Ah, good deal. Thanks, hoss. I am going to try to get a delivery estimate from Grizzly today - if it's more than a couple weeks out, I will just go with one from this guy.
    thanks again
  18. #18
    Jun 2004
    822
    Well, its going to be at least a month. Do you think either of these would be a good replacement?
    Motor 1
    Motor 2
  19. #19
    Jun 2004
    822
    OK, I'm going to buy one of those treadmill motors today. Does it matter that the treadmill motor is 3 wire (red/black/green) and the grizzly motor is 2 wire? Can I just wire it up with the red/black?
  20. #20
    Dec 2004
    1865
    The green wire is normally ground so I don't see a problem but I would check to be sure.
    Mike
Page 1 of 2 12
  1. Hoss's G0704
    By hoss2006 in forum Benchtop Machines
    Last Post: 03-16-2024, 11:51 AM
  2. G0704 Is it normal for the motor to smoke ?
    By evo803 in forum Benchtop Machines
    Last Post: 09-29-2010, 03:20 PM
  3. G0704 problem
    By pike3e in forum Benchtop Machines
    Last Post: 07-27-2010, 10:33 AM
  4. G0704 Gib Problem - Is this fix OK?
    By mrcodewiz in forum Benchtop Machines
    Last Post: 07-23-2010, 03:29 AM
  5. Mach3 , Config, Motor Tuning problem ( FILM OF MOTOR)
    By MDF_Markazi in forum Mach Software (ArtSoft software)
    Last Post: 04-30-2009, 08:15 AM
