Hey guys,
I have been in the process of doing the treadmill motor and belt drive conversion on my G0704 and have had some streaks of bad luck. the latest was receiving the treadmill motor and after half a day of trying to remove the pulley, it finally gave way and revealed why it wouldn't "unthread"... It had a tapered shaft anf the pulley was pressed onto it rather then having the standard reverse threads most others had on their motors.
After some conversation with Hoss (who's excellent plans I am following...Thanks again for your help Hoss!) I decided to try and use the motor anyways. well, making a taper without a lathe is not easy, and with a lathe that isn't cnc's can't be easy so i started on my trek to convert the G0704 into a cnc lathe as well. I ordered an R8 4" 3 jaw lathe chuck from Shars tools (on sale for $81 right now by the way) as well as their $80 quick change tool post kit ~$80 bucks also, and some lathe tools and bits to fit and a boring bar.
after some reconfiguring in machturn, i had it up and runnings. a few minutes of adjusting and tramming and i was ready to give it a whirl. Below are the videos i took using the G0704 coverted to a cnc lathe with Machturn and the lathe wizards which are pretty awesome!
[ame="http://www.youtube.com/watch?v=T-JRTDdSTWE"]Turning a taper[/ame]
[ame="http://www.youtube.com/watch?v=IokXuAicx_A"]Tapered pulley fitment and results[/ame]
[ame="http://www.youtube.com/watch?v=mLw5sh9A6P8"]ID boring and facing[/ame]
Forgive the poor camera work in some of them, it was taken with my phone and the audio isn't the best. will get better next go at it!
Also, This is my first go at turning so i am sure the feeds and spindle speed could be adjusted but the finish was amazing so it worked fine this time!
Thanks for looking,
Chris
