588,687 active members*
6,497 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > G0704 Spindle bearing removal
Results 1 to 4 of 4
    Mar 2015
    6
    I'm hoping you all may have some suggestions or maybe even dealt with the same issue I've run into. I was planning on upgrading the spindle bearing in my G0704 but I can't seem to remove the bearing nut from the spindle. I've removed the 2 screws from the nut but the nut itself wont budge. There's 2 flat bottomed holes on the nut as well that look like some type of tool could fit in. Is there some tool I need to remove it or did the factory just put the nut on too tight?
    Re: G0704 Spindle bearing removal
    You can make a tool like this perhaps.
    Hoss
    Attached Thumbnails Attached Thumbnails G0704 spindle upper spanner wrench.jpg   IMG_5171_800x600.jpg
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
    Mar 2015
    6
    That looks like it'll work perfectly. Thanks for the print.
    i took a 2-inch adjustable face spanner and drilled a couple of holes in it., worked on both sides, just used longer screws.
  1. mazak vtc41 spindle bearing removal
    By jblmfg in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-11-2020, 02:19 AM
  2. Okuma Howa VMC spindle bearing removal
    By aryoung19 in forum Okuma
    Last Post: 06-28-2017, 08:27 PM
  3. lathe spindle tapered bearing race removal
    By auburnCNC in forum Uncategorised MetalWorking Machines
    Last Post: 10-28-2012, 02:17 PM
  4. Spindle Bearing Removal
    By RustedOut in forum Charter Oak Automation Support Forum
    Last Post: 07-03-2011, 04:20 PM
  5. X2 spindle bearing removal
    By skmetal7 in forum Benchtop Machines
    Last Post: 04-14-2007, 07:25 PM
