603,935 active members*
4,343 visitors online*
Results 1 to 11 of 11
    Nov 2011
    G0704 Z axis conversion
    Hi.
    I got G0704 and want to connect Z axis to steper motor as it shows on attached drawing and encountered a problem, since unable to figure out exact tap size on the end of Z axis as it shows on the attached picture.
    According to G 0704 manual thread size should be M16-2 metric. But it's incorrect, because I measured it myself and it showed as M16-1.5 or 5/8-18. Please help me with correct thread size, so I can order Shaft Collar per drawing.
    Attached picture was found on the net and I cant find the source anymore.
    Thank you.
    Feb 2006
    7063
    Is there a reason you can't simply measure it?? That's the surest way to KNOW what the actual thread on your particular machine is....
    Regards,
    Ray L.
    Oct 2010
    266
    Well i dont quite see the problem. if you measured it and it is M16x1.5 then i guess it is such. go on ahead with your plans
    Nov 2011
    Correction: I think it is 16-1.5 or 5/8-18, since I cannot measure it. 3 stores I visit were unable to help me to check correct thread size.
    So, if someone had to deal with G 0704, please help me to find out thread size. Then I will be able to order necessary parts online.
    Feb 2006
    7063
    There are NO imperial threads on these machines (other than drawbars, and a very few other specific places where interoperability is required), so it will NOT be 5/8-18. If you really want to make sure buy a 16x1.5 nut and see if it fits....
    Regards,
    Ray L.
    Quote Originally Posted by pemko View Post
    It's M16x1.5, just pulled my old one out to check.
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
    Nov 2011
    Quote Originally Posted by hoss2006 View Post
    Hoss
    Thank you, Hoss.
    Do you know, by chance, where I can order Threaded Clamping Shaft Collar M16-1.5? Maybe somewhere in Chicagoland.
    It's fairly easy to find M16x2.0, mcmaster even carries them but Misumi USA seems to carry the M16x1.5 for $6.38.
    Shaft Collars - Threaded I. D., Slit | Mechanical Components for Assembly Automation - Misumi eCatalog part #SCSN16A
    Hoss
    Mar 2009
    1114
    I like the design with the pinch collar. Not sure I've seen that yet.
    I would beef up that mounting plate though. Especially if you plan on making it out of aluminum.
    Nov 2011
    Hoss
    Thank you for a good hint, Hoss.
    I ordered necessary part from their site and it was delivered quickly.
    Thank you for the help.
    Stepan.
    Happy to help, you're welcome.
    Hoss
  1. New G0704 - CNC Conversion
    By feederic in forum Benchtop Machines
    Last Post: 11-21-2012, 05:42 AM
  2. G0704 X axis conversion
    By pemko in forum Benchtop Machines
    Last Post: 02-28-2012, 03:07 AM
  3. G0704 Conversion
    By rcazwillis in forum Benchtop Machines
    Last Post: 07-17-2011, 03:27 PM
  4. My Grizzly G0704 Conversion to CNC
    By DrewSmith007 in forum Benchtop Machines
    Last Post: 04-11-2011, 05:42 AM
  5. g0704 - conversion project
    By dsdmax in forum Benchtop Machines
    Last Post: 03-02-2011, 04:03 AM
