I need 200 of each of these two files. Tolerance is +- .01" I need them milled with a 1/4" ball mill with 1/8" step over at a 45 degree angle to create a texture similar to the picture attached with both sides of the knife going the same direction once they are attached (basically a 3D planar slice one side at 45' the other at 135').
I will supply the material which comes in .25"x8.5"x11.5" sheets. I can get larger sheets up to 4'x8' if it helps to lower the costs.
I need this to be completed and parts in my possession within 6 weeks after you receive the material, my zip code is 98387. If you get the bid the materials will be shipped Monday morning and should arrive anywhere in the USA within 5 days. Bidding is open until 8AM Sat Aug 11th. You must be a reputable shop and not a hobbyist to be considered for the job. Absolutely no one outside of the USA will be considered. All of my products are completely made in the USA.
Thankyou,
Harlen Shaw
harlen@shaw-shanks.com
shaw-shanks.com
