587,999 active members*
1,719 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > G154 Select Work Coordinates Help
Results 1 to 5 of 5
    Nov 2007
    188
    In my haas manual it shows additional work offsets P1 to P99 you use G154
    P1 and so on like the G54.1 P1 on other controls Then it shows #14001-#14006 I am ussuming this is the register where you would put your X,Y,Z,A,R vaules. Now the Dumb question where do you find these registers in the control to view what is in them I am thinking you could enter the value in them like this #14001=10.6 from the program is this correct I do some thing simular on a fanuc.
    Jul 2005
    12177
    The G154 P(whatever0 work offsets all show up on the work offset page and you enter values into them the same as any work offset; cursor down to the appropriate line and use the work zero key or type in the values and press Write or F1.
    If you want to enter from the program use G10.
    Nov 2007
    188
    work offsets
    Geof
    on my work offset page I have
    G52
    G54 to G59
    G110 TO G129 These would could be call by G154 P1 to P20
    G92
    Not counting G52 and G92 thats 26 Offsets I can use I need 32 for a tomb stone
    Book also shows
    G154 P21 to P30
    P40,P50,P60,P70,P80,P90
    and P95 to P99
    with what the book shows above there should be 21 more offsets I could use but these do not show on the work offset page. My mill is a was made in 1999 my book says 2004 maybe my mill is to old and does not have this option ?
    Sep 2006
    81
    I think your mill is just a good deal older than the software on your machine, so there are less work offsets available to you.
    Jul 2005
    12177
    Quote Originally Posted by chucker View Post
    .. My mill is a was made in 1999 my book says 2004 maybe my mill is to old and does not have this option ?
    Correct, too old, but have you read up on G52 or done a search here for threads discussing G52? Using G52 is an alternate method of getting an unlimited number of work offsets. Also using G10 you can change offsets from the program so again you can get many more than simply using fixed offsets.
  1. Yasnac MX2 work coordinates.
    By PHD in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-15-2021, 09:21 PM
  2. G92 coordinates
    By monaro mike in forum Fanuc
    Last Post: 08-07-2018, 06:27 PM
  3. Work Planes / Work Coordinates
    By MICFDI in forum Esprit
    Last Post: 10-04-2014, 02:41 PM
  4. losing work coordinates at power off
    By jlong58 in forum Fanuc
    Last Post: 07-27-2007, 11:31 AM
  5. Okuma Work Coordinates
    By firedog in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-10-2005, 12:43 AM
