603,546 active members*
3,468 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > G30(reference point return)
    May 2008
    10
    Does anyone know how to set G30 (reference point return) on a lynx 200L with a fanuc 21i control. I tried changing 1244 parameter but didnt work. Maybe I'm doing something wrong. I appreciate any input.
    thankx
    Mar 2003
    2932
    1240 is 1st zero (G28)
    1241 is 2nd zero (G30 or G30 P2)
    1242 is 3rd zero (G30 P3)
    1243 is 4th zero (G30 P4)
    don't know what 1244 is.
    all values are in MM
    May 2008
    10
    I'm sure 1244 is not correct.I knew it was some where in that vicinity.Thanks, Ill try this and get back.
    thanks again for your help.
  1. Fanuc Zero Reference Return Problems?
    By grege101 in forum Fanuc
    Last Post: 09-19-2023, 12:52 PM
  2. Busellato Optima Point To point
    By Malacara in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-12-2007, 01:22 AM
  3. converting point to point programs
    By kevinwd1 in forum Uncategorised CAM Discussion
    Last Post: 06-11-2007, 05:45 PM
  4. Point to point programs
    By Frankbals in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-22-2007, 09:12 PM
  5. Return through reference point?
    By RBrandes in forum Haas Mills
    Last Post: 12-02-2005, 04:49 PM
