587,529 active members*
3,272 visitors online*
IndustryArena Forum > CAM Software > Mastercam > G32 outputs E instead of F
Results 1 to 8 of 8
    Mar 2003
    63
    I have a haas SL-30
    Mastercam X5 using Lathe Default
    I want to thread using G32 command but it outputs a E instead of F
    It's set up for NC code format: Long Hand
    Snippet of the code is below,
    G20
    G0 T707
    G18
    G97 S200 M03
    G0 G54 X1.9823 Z.2115
    X2.2085
    G99 G32 Z-1. E.0625
    I wanted to change the "E.0625" to "F.0625"
    when it outputs the g-code.
    I looked in the post but it's not obvious where to change it.
    Any idea how to do it?
    Tony
    [email protected]
    http://www.xenomechanics.com
    May 2004
    4519
    Upload a copy of the post processor you are using.
    Dec 2008
    3127
    Quote Originally Posted by txcncman View Post
    Tx,
    please do not be offended, but
    -why has everyone have to upload their post to a public forum for you & everyone else to see.
    Many put hard earned hours/days/weeks into that post, just to have some piracy noob knock it off.
    It is in all legal user's interest to show a little restraint, in giving away a complete post. I also find it better to guide the thread starters into doing it themselves, ( so they learn post editting in the process )
    Xeno
    - read the upper section of your post, tells you how to program your part while using this post
    Look in your post (general output settings) for the "thread_address" setting, change it from 1 to 0 to have F output instead of the E.
    (didn't have a Haas post, this is from the MplmasterX5.pst....it should be nearly identical)
    Code:
    # General Output Settings
    force_wcs    : yes$  #Force WCS output at every toolchange?
    progname$    : 1     #Use uppercase for program name
    css_start_rpm : yes$   #Do direct RPM spindle start prior to CSS?
    css_end_rpm  : yes$   #Do direct RPM spindle prior to Retract?
    prog_stop    : 1     #Program stop at toolchange: 0=None, 1=M01, 2 = M00
    tool_info    : 3     #Output tool information?
                         #0 = Off - Do not output any tool comments or tool table
                         #1 = Tool comments only
                         #2 = Tool table only
                         #3 = Tool comments and tool table
    use_pitch    : 0     #0 = Use feed for tapping (force Feed/Min), 1 = Use pitch for tapping (force Feed/Rev)
    rigid_tap    : 1     #0 = Floating tap output
                         #1 = Rigid tap output (Set parameter 5200 bit 0 to 1 for rigid)
                         #(Set M code for rigid tap in parameter 5210)
    tap_feed     : 1     #0 = 2/1 (in/mm) decimal places, 1 = 4/3 (in/mm) decimal places
    thread_address : 1   #Thread pitch address for lathe threading, 0 = Use F, 1 = Use E
    use_clamp    : 1     #0 = No, 1 = Clamp
    use_brake    : 1     #0 = No, 1 = Brake
    May 2004
    4519
    Because his post might not use that method for output? Now, I guess he could be asked, "Does your post have this line...?" Then told, "Change it to this..." But then you can get into a lot of back and forth exchanges of, "I didn't find that. Now what do I do." So, to me, it is easier to cut the chase and see the post myself. Everyone has their own style. I do not mind trying to help - if helping is not made too difficult. Just because we differ on methods, and having butted heads in the past, I will try to leave all future MasterCam questions for you, the expert, to answer them, no matter how many days it might take you to get around to answering them (if ever at all). Have a nice day.
    Mar 2003
    63
    I have the default post mcamx5/lathe/post/MPLFAN.pst
    the clip of Tx's post above isn't in my post.
    I don't see any options for using either E or F
    What does work is changing the stre variable of the clip below...
    #String and string selector definitions for NC output
    #Address string definitions
    stra : "A" #String for address A
    strd : "D" #String for address D
    stre : "E" #String for address E
    strf : "F" #String for address F
    ... so changing it to
    stre : "F" #String for address E
    For my 2001 Haas SL30 I never use the parameter "E"
    Tony
    [email protected]
    May 2004
    4519
    The expert will get to this in his own time frame. Good luck.
    Dec 2008
    3127
    Quote Originally Posted by Xeno View Post
    That will work, but,,, if there is any other place that requires an E address, it will pump out an F.
    If you want to alter the area that controls that output, this may be the best option
    look in your post for the "Motion output components" section
    - it is a "feed" component that we need to find
    in the post for G32 threading, it looks for a pffr for the feed calcs
    - pffr first does the pfr_l postblock before outputting the feed address, which has the change of F to an E, we need to comment that actual part out, but we need to keep everything else. The next line is a format statement for how many decimal places, you need threading (which is opcode$=104) to be accurate. So it will take up 5 decimal places in inch mode ( fs19
    Code:
    pffr            #Output feedrate, force
           pfr_l
          *feed
    pfr             #Output feedrate
           pfr_l
          `feed
    pfr_l           #Format feedrate for lathe
          if opcode$ = 104,
            #Format feedrate for lathe thread
            #result = nwadrs(stre, feed)
            result = nwadrs(strf, feed)
            result = newfs (19, feed)
          else,
            result = newfs (18, feed)
    Put the red #, & you should be good to go
    or you could do what is marked in blue....change the E output to F, which doesn't change it at all.
    ----- this is what you suggested, but in the incorrect area
    Jan 2007
    243
    Not sure why output with an E instead of an F is so undesirable? I know that when E is used you can actually carry the feed to 6 decimal places for greater accuracy.
    Machining Formulas
    www.WebMachinist.Net
    The Ultimate Online Source for Machinist Related Stuff!
  1. How to use auxiliary outputs
    By mscrw in forum Mach Wizards, Macros, & Addons
    Last Post: 04-22-2011, 03:33 AM
  2. Mach 3 outputs
    By dolomitedave in forum CNC Machine Related Electronics
    Last Post: 02-27-2011, 12:01 AM
  3. marvel saw plc outputs
    By Craigweld in forum CNC Machine Related Electronics
    Last Post: 06-24-2010, 02:30 PM
  4. different outputs
    By oest in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-23-2010, 04:59 AM
  5. X3 - How to get arc outputs in the X/Z plane?
    By colton_m in forum Mastercam
    Last Post: 03-03-2010, 07:22 AM
