603,946 active members*
2,832 visitors online*
    Dec 2003
    56
    G320 Fault & Mach3
    On some occasions, and I plan to address the cooling issue which I think is faulting the gecko, my drive will fault and stop the servos. However, Mach 3 keeps on doing its thing thinking everything is ok.
    Is there a setting for this, to stop the gcode? I just read a good portion of the Mach3 manual, and didn't see it. My limit switches work fine and stop Mach3.
    If I get a fault, I want everything to stop. Makes it easier to figure out where I am in the gcode cycle too!
    Thanks in advance.
    Mar 2003
    35494
    You need a circuit to provide Mach with the fault signal from the Gecko's. I think there used to be one here somewhere, but I couldn't find it. I did find this, though.
    http://www.casa.co.nz/Equipment/Cont...Controller.htm
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Dec 2003
    56
    Thanks for the link, think I will buy one.
    Hint, anyone building a control box for Geckos should incorporate the items mentioned in that thread.
    HUGE difference in troubleshooting, and basic safety.
    I like it, and most likely worth every penny.
  1. g320-TESTING
    By LYN BYRD in forum Gecko Drives
    Last Post: 06-25-2008, 07:42 PM
  2. G320 not singing?
    By Chris64 in forum Gecko Drives
    Last Post: 01-31-2008, 03:01 AM
  3. G320 heatsinks
    By beezerlm in forum Gecko Drives
    Last Post: 01-10-2008, 06:49 AM
  4. Tie G320 fault line to something ?
    By embeddedJunkie in forum Gecko Drives
    Last Post: 05-31-2007, 05:37 PM
  5. G320 Fault light doesn't turn off
    By lamote in forum Gecko Drives
    Last Post: 04-11-2005, 10:39 AM
