588,206 active members*
4,292 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > G320 make my servo turn only one way
    Feb 2004
    77
    I use G320 and Mach3 to turn my servo.
    My servo turns CW perfect but when I try CCW G320 fails.
    I tried to reverse encoder and motor power leads. Nothing changed. Again motor turns CW perfect but can not turn CCW.
    My direction signal is correct. when I reverse encoder and motor leads I have to press negative X jog button to turn motor CW. Before changing leads I have to press positive X jog button.
    Is there anyone who has experience about motors turning only one direction :withstupi
    Gunol Camlibel
    [email protected]
    http://www.rc-tuning.com
    Feb 2004
    77
    Today I disconnected all wires and reconnect them with fresh mind. Now my motor turns perfect.
    Thanks for reading. Sorry for taking your time
    Gunol Camlibel
    [email protected]
  1. Problem with servo controller (G320)
    By faststeve in forum Gecko Drives
    Last Post: 04-04-2007, 02:18 AM
  2. Some servo help and questions about the G320/340
    By Eson in forum Gecko Drives
    Last Post: 02-07-2007, 10:01 PM
  3. g320 48v servo will this work
    By dgalaxy in forum Gecko Drives
    Last Post: 05-30-2006, 02:10 AM
  4. G320 Fault light doesn't turn off
    By lamote in forum Gecko Drives
    Last Post: 04-11-2005, 10:39 AM
  5. G320 and back-EMF from servo
    By rc-cellar in forum Gecko Drives
    Last Post: 02-18-2005, 04:15 AM
