603,793 active members*
2,752 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > G320 receiving feedback from linear scale
Results 1 to 4 of 4
    Jan 2005
    72
    Instead of using the conventional encoder mounted onto the servo motor shaft, I am thinking of connecting a linear scale with a compatible signal onto the feedback inputs of the G320's.
    This will allow to compensate for all the issues coming from reduction pulley system, ballscrew acuracy, backlash, etc.. Therefore it would just be one step short of telling to the CNC controller where we are exactly.
    Given that this is not comon practice, am I missing something out which jeopardizes this approach or is it just a price issue ? Many do already have linear scales fit for DRO so the signal could be fed easily to the drives.
    Oct 2004
    742
    Linear scales are used on many high quality CNC machines which require extreme accuracy.
    The main reason they are not so common is price, oils and coolants and trash getting into the unit electronics. Most linear scales are made of etched glass.
    Congratulations.
    Dec 2003
    24260
    This recent post explains some of the problems.
    http://cnczone.com/forums/showthread.php?t=24817
    Al.
    Albert E.
    Jan 2005
    72
    Al thanks a lot for putting me onto this thread. Spot On !!
    reading this I think it is the way to go.
    rotary encoder on the servo or stepper
    linear scale on the table
    cheap rolled ballscrews
    proper table guideways
    proper ballscrew bearing
    hardware able to collect the 2 feedbacks
    Mach 3 plug in to sort it all out.
    I am looking forard to this day to come
    Daniel.
  1. linear scale interface with servo
    By machinemman in forum Linear and Rotary Motion
    Last Post: 03-17-2007, 04:10 PM
  2. Linear Scale interface ??
    By routerman in forum Bridgeport / Hardinge Mills
    Last Post: 02-03-2007, 06:28 PM
  3. IH Kit & Linear Scale
    By SMW Precision in forum Charter Oak Automation Support Forum
    Last Post: 04-17-2006, 11:18 PM
  4. linear glass scale error?
    By beezerlm in forum Uncategorised MetalWorking Machines
    Last Post: 03-23-2006, 05:40 PM
  5. Homemade Linear Design, Feedback.
    By MrBean in forum Linear and Rotary Motion
    Last Post: 05-20-2005, 08:50 AM
