I think stucapco may have chopped it a little too far,
you may need to modify the "capsmill" post to have it output in a similar format
- but this is my take on the NC code, ( I currently work a Fanuc OM control mill )
- maximum (1) M-code on any line
Code:
O0002 ( ABC-OP1) ( comment on O line shows up on program list page of the machine )
(DATE-DDMMYY) (04-03-2015)
(setup info here)
(tool list here)
( T12 = 14.00 MM. DIA. TWIST DRILL )
( H2 , D42 )
( T9 = 18.00 MM. DIA. END MILL-FINISH-2 FLUTE)
( H9 , D39 )
G21 ( inch/metric code check) ( if machine is set to other code, program stops)
G0 G17 G40 G80 G94 M5 ( safety codes)
G91 G28 Z0. ( retract vertical to Z home position )
G90
N1
T12 M6 (14.00 MM. DIA. TWIST DRILL) ( load tool )
T9 ( pre-select next tool, only needed if machine has toolchange arm )
N11
(DRILL)
G54 ( co-ordinate system selection, always define at the start of each tool operation, reset may change it back to G54 by parameter default )
G0 G90 X15. Y-15.
S636 M3
G43 H12 Z100. M8 ( take up length offset, point to Z100, coolant ON )
G98 G81 Z-30.206 R3. F63.662 ( G98=Retract to R-plane, G99= retract to Z level before canned cycle( in this case Z100. for jumps over clamps etc)
X47.5 G99 ( retract to Z100, before moving to next position
X80. (G98 retract to Z3 ( R value in canned cycle))
X112.5
G80 G94 ( cancel canned cycle, units per minute ( in case G95 gets used for any operation )-safety codes)
M5
M9
G91 G28 Z0.
G90 ( always leave it in absolute mode)
M1 ( optional stop here for checking previous machining before swapping tool out)
N2
T9 M6 (18.00 MM. DIA. END MILL-FINISH-2 FLUTE)
T12
N22
(SIDE MILLING)
G54
G0 G90 X127.500 Y-32.575
S627 M3
G43 H9 Z100. M8
Z3.
G1 Z-4. F70.3
X0. F100.4
G0 Z3.
X127.5
Z-3.5
G1 Z-8. F70.3
X0. F100.4
G0 Z3.
X127.5
Z-7.5
G1 Z-12. F70.3
X0. F100.4
G0 Z3.
X127.5
Z-11.5
G1 Z-13.8 F70.3
X0.F100.4
G0 Z3.
S717 M3
X127.5
Z-13.5
G1 Z-14. F50.2
X0. F71.7
G0 Z3.
X127.5 Y-32.375
G1 Z-14. F50.2
G41 D39 X136.375 F71.7
G3 X127.5 Y-23.5 I-8.875 J0.
G1 X0.
G3 X-8.875 Y-32.375 I0. J-8.875
G1 G40 X0.
G0 Z3.
( SIDE MILLING )
S627 M3
Y2.575
G1 Z-4. F70.3
X127.5 F100.4
G0 Z3.
X0.
Z-3.5
G1 Z-8. F70.3
X127.5 F100.4
G0 Z3.
X0.
Z-7.5
G1 Z-12. F70.3
X127.5 F100.4
G0 Z3.
X0.
Z-11.5
G1 Z-13.8 F70.3
F100.4
X127.5
G0 Z3.
S717 M3
X0.
Z-13.5
G1 Z-14. F50.2
F71.7
X127.5
G0 Z3.
X0. Y2.375
G1 Z-14. F50.2
G41 D39 X-8.875 F71.7
G3 X0. Y-6.5 I8.875 J0.
G1 X127.5
G3 X136.375 Y2.375 I0. J8.875
G1 G40 X127.5
G0 Z3.
G80 G94
M5
M9
G91 G28 Z0.
G91 G28 X0. Y0.
G90
M30
See how this goes in your machine ( lowercase letters will need to be removed )
The arcs in the finishing paths are the "lead in & lead outs that the CAM system had set,
- you need to understand that function in CAM.
Do not allow the cutter to plunge down while against a finished edge, it will leave gouges
Remember this....cutter comp MUST be taken up ( or cancelled )on a linear move, it cannot be done on an arc
