hi ,guys my question is: is there a problem if I activate cutter comp. on a z movement and I am not sure if it only work on the G1 line and if it matters if G40 would be in the las cutting movement or is nessesary to put g40 only onthe exit movement.I have been experienced problems like alarms and tapered surfaces where i nedded straight movements . any tips or insights would be fine ,thankyou for your time and help.
