I'm having an issue when using tool offsets. I have tool number 1 defined in the tool file with a length of 1.975". When I issue G43 H1 it sets the tool offset to 1.975 and subtracts the length from the current Z position.
The problem is that it continues to subtract 1.975" on every machine movement until I issue G49 to cancel the tool offset. If I explicitly provide a Z value it doesn't do this. So,
G0 X0 Z0
G0 X1 Z0
G0 X2 Z0
moves one inch to the right on the second and third lines
G0 X0 Z0
G0 X1
G0 X2
moves one inch to the right and 1.975” down on the second and third lines
I noticed there’s a similar bug reported on the Sourceforge site, although that reported that the tool was moving downwards more than the tool length.
Am I doing something wrong in the GCode? I am issuing T1M6 previously, although I don’t believe it has any bearing on the tool offset.
Is this a bug in EMC? If so, does anyone have a good workaround? I could use the coordinate systems to compensate for the tool lengths, but then I’d be coding them into my programs.
Thanks,
Steve
