Ok after reading the manual plenty of times and reading heaps on the net I still have questions about the use on g50 in the work offset
I get that the g50 x.. Z.. Are the distance from the work piece zero to the tool tip but how does the following work
Lets say I have a rougher turning tool in pos 1 and the g50 is x150 z 200 and the stock 0 is the front of the stock.
This particular op take 3 tools how does things when I do a tool change ? Is the offset amount stored in the control just the difference between the 3 tools and say tool 1 will be a master tool that I always use to set work zero?
So if the g50 is always x150 z200 but in the offsets I have the following
tool 1 as x0 z0 (master tool)
Tool 2 as x10 z5(finisher tool with 10mm more stick out in x and 5 more in z)
Tool 3 x -150 z10 (centerline tool like drill bit)
Am I even on the correct path with this set up?
