587,773 active members*
3,237 visitors online*
    Jan 2016
    40
    G53 Snap! What the? Why?
    Hey all,
    I'm running a Haas ST20Y. I figured I'd step out of my G28 tool change comfort zone, and try changing tools closer to the work. Not working out too well for me. I wrote up a little simple operation in MDI and it worked great. I put the tool close in to the chuck, wrote in G53 Z-9.; T1111;, hit cycle start, turret rapided away from the current arbitrary location to Z-9., changed tools, cool! everything seemed to work groovy. Tool change an inch away from my longest drill bit. Now apply it to my actual NC code in place of G28. Cycle start, covering feed hold, tool changes looked great, then we got to peck drilling with my longest bit. Finished the operation, and snap! The thing tried to change tools while the bit was still about two tenths inside the part. Huh, ok? Changed all my G53 Z depths to G53 Z-7. Replace tool. Run again. Snap! Tool did not retract any farther with the new Z depth. Still tried to do the tool change at about two tenths inside the part. Is this some sort of modal precedence thing? I'll post some of the code so ya'll can take a look. Don't tear me down too hard I'm self taught.
    (MATERIAL - STEEL INCH -)
    G20
    (TOOL - 2 OFFSET - 2)
    (OD FINISH RIGHT - 35 DEG. INSERT - VNMG-431)
    G00 T0202
    G18
    M08
    G97 S1400 M3
    G00 G54 X1.575 Z.02
    G50 S3600
    G96 S600
    G99 G01 X-.0313 F.008
    G00 Z.12
    X1.575
    Z.01
    G01 X-.0313
    G00 Z.11
    X1.575
    Z0.
    G01 X-.0313
    G00 Z.1
    G96 S510
    X1.301
    Z.12
    G01 Z.02 F.01
    Z-1.4634
    X1.375
    X1.5164 Z-1.3927
    G00 Z.12
    X1.227
    G01 Z.02
    Z-.356
    G18 G3 X1.29 Z-.3957 R.0406
    G1 Z-.6406
    Z-1.4634
    X1.321
    X1.4624 Z-1.3927
    G0 Z.12
    X1.153
    G1 Z.02
    Z-.355
    X1.2087
    G3 X1.247 Z-.3598 R.0407
    G1 X1.3884 Z-.2891
    G0 Z.12
    X1.079
    G1 Z.02
    Z-.355
    X1.173
    X1.3144 Z-.2843
    G0 Z.12
    X1.005
    G1 Z.02
    Z-.355
    X1.099
    X1.2405 Z-.2843
    G0 Z.12
    X.931
    G1 Z.02
    Z-.355
    X1.025
    X1.1665 Z-.2843
    G0 Z.12
    X.8571
    G1 Z.02
    Z-.355
    X.951
    X1.0925 Z-.2843
    G0 Z.12
    X.7831
    G1 Z.02
    Z-.355
    X.8771
    X1.0185 Z-.2843
    G0 Z.12
    X.7091
    G1 Z.02
    Z-.355
    X.8031
    X.9445 Z-.2843
    G0 Z.12
    X.6351
    G1 Z.02
    Z-.0274
    X.662 Z-.0409
    Z-.2656
    Z-.355
    X.7291
    X.8705 Z-.2843
    G0 Z.12
    X.5611
    G1 Z.02
    Z.0096
    X.6551 Z-.0374
    X.7965 Z.0333
    M09
    G53 Z-9.
    T0200
    M01
    (TOOL - 1 OFFSET - 1)
    (OD GROOVE RIGHT - NARROW INSERT - GC-4125)
    G00 T0101
    G18
    M08
    G97 S1400 M3
    G00 G54 X1.4832 Z-.375
    G50 S3600
    G96 S600
    G01 X.54 F.006
    G00 X1.4832
    X1.49
    Z-.75
    G01 X1.123
    G00 X1.49
    M09
    G53 Z-9.
    T0100
    M01
    G00 T0202
    G18
    M08
    G97 S1400 M3
    G00 G54 X1.3043 Z-.73
    G50 S3600
    G96 S600
    G01 Z-1.4634 F.01
    X1.375
    X1.5164 Z-1.3927
    G00 Z-.73
    X1.2337
    G01 Z-1.4634
    X1.3243
    X1.4658 Z-1.3927
    G00 Z-.715
    X1.163
    G01 Z-1.3706
    Z-1.4634
    X1.2537
    X1.3951 Z-1.3927
    G00 Z.0954
    X.5328
    G01 Z-.0046 F.008
    X.622 Z-.0492
    Z-.2656
    Z-.375
    X1.2087
    G18 G3 X1.25 Z-.3957 R.0207
    G1 Z-.635
    X1.3914 Z-.5643
    G18
    G00 Z-.735
    X1.123
    G01 Z-1.3706
    Z-1.4834
    X1.2644 Z-1.4127
    G00 X1.49
    M09
    G53 Z-9.
    T0200
    M01
    G00 T0101
    G18
    M08
    G97 S1400 M3
    G00 G54 X1.575 Z-1.515
    G50 S3600
    G96 S600
    G01 X1.0554 F.005
    G00 X1.575
    Z-1.4064
    X1.2586
    G01 X1.1171 Z-1.4771 F.006
    X1.0742 Z-1.4985
    X1.0867 Z-1.5048
    G00 X1.5164
    Z-1.5907
    G01 X1.375 Z-1.52
    X1.043
    Z-1.5141
    X1.0742 Z-1.4985
    X1.0867 Z-1.5048
    G00 X1.49
    M09
    G53 Z-9.
    T0100
    M01
    (TOOL - 3 OFFSET - 3)
    (NGDHR-16 - GC-4125 INSERT - NR-3031R)
    G00 T0303
    G18
    M08
    G97 S1155 M3
    G00 G54 X1.323 Z-.695
    G50 S3600
    G96 S400
    G01 X1.019 F.003
    G00 X1.323
    Z-.687
    G01 X1.019 F.004
    X1.0222 Z-.6886
    G00 X1.49
    M09
    G53 Z-9.
    T0300
    M01
    (TOOL - 6 OFFSET - 6)
    (CENTER DRILL- .25 DIA.)
    G00 T0606
    G18
    M08
    G97 S910 M3
    G00 G54 X0. Z.25
    Z.1
    G01 Z-.15 F.005
    G00 Z.25
    M09
    G53 Z-9.
    T0600
    M01
    (TOOL - 4 OFFSET - 4)
    (11/32 DRILL)
    G00 T0404
    G18
    M08
    G97 S730 M3
    G00 G54 X0. Z.25
    G83 Z-.6986 R.1 Q.25 F.005
    M09
    G53 Z-9. (SNAP!)
    T0400
    M01
    Best I can figure is the G53; T-whatever needs to come after the M01 maybe?
    Any help would be greatly appreciated
    Kyle
    BTW yes I'm roughing with a finish tool because I haven't had the funds to buy another tool holder yet. Unless you want to give me one don't judge.lol
    Jan 2009
    104
    Re: G53 Snap! What the? Why?
    Insert a G80 after the G83 line to cancel G83
    Jan 2005
    15362
    Quote Originally Posted by mcode View Post
    Or a G0G53 the G0 will also cancel the G83 caned cycle and make the G53 how it should be used
    Mactec54
  1. Snap issue
    By xxxxxcad in forum Esprit
    Last Post: 03-19-2016, 12:17 PM
  2. Snap Points
    By mcphill in forum BobCad-Cam
    Last Post: 03-18-2016, 09:38 PM
  3. Ghost Snap
    By RAF. in forum BobCad-Cam
    Last Post: 12-10-2014, 07:29 PM
  4. Snap Grid
    By harlen.shaw in forum BobCad-Cam
    Last Post: 10-05-2011, 03:55 PM
  5. Snap-On consumables
    By Captain Midnigh in forum Waterjet General Topics
    Last Post: 01-06-2007, 08:22 AM
