588,546 active members*
4,477 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > G540 intermittent fault light
Results 1 to 7 of 7
    Oct 2008
    85
    Hi everyone,
    I have a home built router with 381oz steppers, a 48v 7.3a PS, and a gecko 540. Everything is about a year and a half old and has been running fine till a few weeks ago. Now my gecko keeps randomly "faulting" and I can't figure out why. It will do this every few seconds sometimes and other times I may run it for an hour or more with no problems. I have checked my wire connections at the motors and all looks good.
    I have spoken to customer support at Gecko and they think it's a power supply problem. I have tested the voltage of my PS and it is putting out 48.3v. They also told me to jog the motors 2 at a time to see if it faults. Sometimes it does, sometimes it doesn't. It is completely random. I sometimes get a red fault light while jogging 1 axis(sometimes x, sometimes y, and sometimes z so I can't narrow it down), any 2 axis', or all 3. a few seconds later, I can do the same test with no faults, even while jogging all 3 at the same time. Once yesterday and twice today it actually faulted while sitting completely still with no motors operating. It has only done this these 3 times. Usually it does it while the motors are moving. Today it faulted more than a dozen times while carving a 2 inch tall letter "A" while running at 100ipm which is where I normally run it(usually 100-120 but occasionally I run this machine at 280-375ipm or more). I then turned it down to 60ipm in Mach 3 and it finished the"A" and then carved a dozen more letters with no faults. Any ideas of what else I should look for. Thanks for any help you can offer on this, Jeff
    Mar 2008
    3655
    Try running awhile with the charge pump switch off on G 540 and disabled in Mach3 and see if it still faults. Just make sure you have mach3 booted up and running well each time you start up, before you turn on power to G 540.
    Are you using limit switches?
    CR
    http://crevicereamer.com
    Too many PMs. Email me to my name plus At A O L dot com.
    Oct 2008
    85
    I do have the charge pump disabled in mach 3 and the switch turned off on g540. No limit switches.
    Mar 2008
    3655
    Do you have home switches installed?
    Do you have another computer to swap and try? Another Parallel cable?
    Have you removed all non-essential programs from windows? EG: virus protection, screen saver etc. These will sometimes cause weird things to happen. The machine computer is not networked or connected to internet, right?
    CR.
    Oct 2008
    85
    I don't have an extra PC or cable to try. PC has just the basics needed for my machine, No internet etc.. Also no Home switches.
    Mar 2008
    3655
    This may be a noise problem. Separate the wires wherever possible.
    Check G 540 terminal block and PSU terminal block for possible loose spider wire that may make intermittant contact with other terminal.
    CR.
    Oct 2008
    85
    Any ideas on what it could be if it faults when the machine is not even moving? I'm still getting the red light when there are no motors running. Sometimes I can unplug the motors from the drive and wait a few minutes before plugging them back in and it works fine again for a while. I haven't found any loose connections in my wiring. Thanks again, Jeff
  1. Gecko G540 - New - Can't get fault light to clear!
    By Vogavt in forum Benchtop Machines
    Last Post: 12-31-2012, 03:19 AM
  2. Intermittent (but persistent!) G540 fault light
    By TiagoSantos in forum Gecko Drives
    Last Post: 08-02-2012, 08:23 PM
  3. G540 fault light...what does that mean?
    By HereinCS in forum DIY CNC Router Table Machines
    Last Post: 03-07-2011, 02:37 AM
  4. Fault Light Stays On G540
    By Bob La Londe in forum Gecko Drives
    Last Post: 08-14-2010, 09:04 PM
  5. G540 Fault light
    By cnccustom in forum Gecko Drives
    Last Post: 01-06-2009, 07:53 AM
