I am building a cnc with the y & A axis slaved together.
I used port 1 pin 10 for the x-axis
I used port 1 pin 11 for the y-axis
I used port 1 pin 12 for the z-axis
I used port 1 pin 10 for the a-axis
I set the mach3 input signals for the same for the Y & A axis
Long story short is that I believe I have all the limit/home switches working and the touch plate connection working correctly, however ; when I attempt to home my machine it cycles to the z-axis I press the home switch and it zeroes correctly, then it goes to the Y/A axis and they zero correctly, then it goes to the x axis and it zeroes correctly then.......
the A-axis motor starts turning (by its self) and I have to press the y=axis limit switch to get it to stop. I have looked through the setting in Mach3 but nothing jumps out at me as to what the solution to this problem is.
Any help to this issue would be appreciated.
