603,365 active members*
2,988 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > G540 questions: XML file and Parallel Port settings
    Nov 2007
    617
    Got my G540 hooked up to my 7x10. I have the green LED and holding torque, indicating that all is well with the G540 and motors.
    Exactly where and how do I apply the XML config file downloaded from Gecko's G540 page?
    Also, my Compaq EVO has EPP + ECP mode for the parallel port, it has no option for just EPP mode. Is this a problem?
    I'm attempting to use Mach, and brief playing around resulted in no joy. I assume this is due to lack of proper configuration in Mach.
    EDIT: I found the joy! I did an initial search before posting but nothing showed up, so I went back out and did a Google search, which resulted in finding a thread explaining how to use the XML file. Once I loaded that, the machine came to life, thereby also answering my second question.
    Nov 2007
    981
    Good for you buddy, looking forward to seeing her running-
    Dave
    Dave->..
  1. G540 PWM Mach settings
    By skidiiii in forum Gecko Drives
    Last Post: 05-17-2010, 02:14 AM
  2. parallel port or parallel universe
    By bruno34 in forum Taig Mills / Lathes
    Last Post: 04-15-2009, 04:58 PM
  3. How do I check parallel port settings?
    By teamtexas in forum DIY CNC Router Table Machines
    Last Post: 10-25-2007, 10:19 PM
  4. port and pin settings not saved?
    By Block16 in forum Mach Mill
    Last Post: 09-26-2007, 02:13 PM
  5. parallel port settings/output signals
    By TMaster in forum Xylotex
    Last Post: 04-24-2006, 05:16 AM
