588,205 active members*
4,119 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > G540 wiring diagram for dummies? :)
Page 2 of 2 12
Results 21 to 28 of 28
  1. #21
    Nov 2008
    214
    Ahh, got it. What's chassis, though? Also, do I need specific resistors or any 2.8k and 3.5k resistors will do?
  2. #22
    Mar 2008
    3655
    Quote Originally Posted by bkboggy View Post
    Chassis is basically the frame of the equipment that is also grounded to the Power Supply ground.
    1/4 watt axial lead resistors.
    CR.
  3. #23
    May 2010
    33
    G540 Motor Connection Polarity
    Does the polarity of the connections going to the steppers matter as long as they're wired to the correct coil? I've seen multiple diagram's, even from the same source that seem to contradict. Here are some examples. That Gecko manual does not identify polarity on the pins, just which are A or B wires.
    Attached Files Attached Files
  4. #24
    Dec 2007
    362
    Polarity does matter hence the pairs of wires being marked A+, A-, B+, B- etc.
    Regards
    Geoff
  5. #25
    May 2010
    33
    Quote Originally Posted by tumutbound View Post
    Great ... now which pins, 6-9 are + and which are - on the G540 DB-9? Does A and /A or B and /B mean something to you?
  6. #26
    Oct 2008
    406
    Quote Originally Posted by poopy_pants View Post
    According to the G540Wiring.pdf the pinouts are
    A+ 9
    A- 8
    B+ 7
    B- 6
    Note that the schematic for the Keiling steppers have the A and B coils drawn opposite from those on the G540 schematic. The A and B positions are reversed.
    Bob
    "Bad decisions make good stories."
  7. #27
    May 2010
    33
    Quote Originally Posted by bobsch View Post
    A+ 9
    A- 8
    B+ 7
    B- 6
    Exactly. The first 2 docs I attached were both from Keling and show
    A+ 9
    A- 8
    B+ 7
    B- 6
    However if you look at post #4, their own doc shows another motor model wired reversed. The 3rd doc I attached from Homann shows them reverse as well from the first 2. I'm not feeling totally confident here and the manual from Gecko directly doesn't say + or - just A and B.
  8. #28
    Oct 2008
    406
    I think Homann's got it backwards. /A and /B are the same as A- and B-
    Bob
Page 2 of 2 12
  1. WIRING DIAGRAM FOR NEW SX3
    By Crevice Reamer in forum Syil Products
    Last Post: 04-29-2009, 04:40 PM
  2. Wiring diagram
    By jdmyers in forum Bridgeport / Hardinge Mills
    Last Post: 11-03-2008, 11:25 AM
  3. help with wiring diagram for C6 CNC
    By JDsto in forum Syil Products
    Last Post: 01-10-2008, 01:37 AM
  4. Wiring Diagram
    By SCHMEOW in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-21-2007, 05:40 AM
