588,533 active members*
9,173 visitors online*
Results 1 to 6 of 6
    Feb 2006
    22
    G540 Z AXIS PROBLEM
    i have a gecko g540 on a k2 cnc machine
    i am using a vcarve program has lot of z movement all obsolute
    the problem i have is the z axis every letter i engrave keeps losing depth
    untill it will stop touching part.i recheck my tool offset and it
    will be .030-.040 higher than it was set to.i run program 1.0 above part with no
    spindle running and get same results.i run z up and down with dial indicator about 50 times
    and it repeats every time x y work no problem.
    any ideas.
    Jan 2011
    Tool moving up in holder? Mark the tool or measure the length sticking out. Run the program and measure the length or check your mark.
    Feb 2006
    22
    i have .500 dia. adapter bottomed out in spindle and i have flat ground on
    .125 60 deg carbide engraving tool but to eliminate i will check z to main
    z gantry before and after running program,i had also check tool for any
    chipping did not see any. thanks for reply.
    Nov 2009
    29
    Also check any slack between the leadscrew and the Z stepper. Maybe you have a loose shaft collar there. Try lifting your spindle by hand and you'll see.
    Feb 2006
    22
    could not find any problem i changed my progam to just regular engraving
    letters and it worked with no problem.
    only thing i can figure is gecko control must loose steps with all the
    z movment thier is a small z move on almost every line of the program of 4000
    lines for 25 letters.using bobcad to program.only good thing it loses depth.
    i ran v carve program again after engraving same problem
    Mar 2003
    35538
    Cut your Z acceleration in half and then try it.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  1. g540 problem
    By draxus in forum Gecko Drives
    Last Post: 07-11-2011, 06:35 PM
  2. Odd Y axis problem with G540
    By mhackney in forum Gecko Drives
    Last Post: 07-25-2010, 12:56 AM
  3. Problem with G540
    By hab82 in forum Gecko Drives
    Last Post: 04-30-2009, 10:21 AM
  4. g540 y axis problem
    By meck11 in forum Gecko Drives
    Last Post: 03-31-2009, 08:57 PM
  5. G540 Rev.1 has problem
    By sse4 in forum Gecko Drives
    Last Post: 02-25-2009, 02:48 PM
