586,072 active members*
4,390 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > g704 Conversion and Fusion 360
Results 1 to 4 of 4
    Im finishing up converting my g704 to a CNC, and will be using Mach 3 controller. I do all my designs in Fusion 360, and would like to also do the gcode setup there instead of something like cam bam. Has anyone setup a g704 conversion in fusion 360 as a machine? If so what all settings did you use? I am not sure if this is a question for this sub form, or the fusion 360 sub forum, but figured id start here. Any help or direction in getting the machine added in 360 would be appreciated.
    Thanks.
    Dec 2013
    5717
    Re: g704 Conversion and Fusion 360
    Fusion 360 has few Mach3 post processors. The fact that you have a G704 makes no difference, only the controller software is important.
    Jim Dawson
    Sandy, Oregon, USA
    Quote Originally Posted by Jim Dawson View Post
    Ok i wasnt sure, so the machine doesn't make any difference, as long as when you do the post processing you use a mach3 processor? I thought that was the case, but wanted to make sure
    Dec 2013
    5717
    Quote Originally Posted by biohazarde View Post
    Yes, that is correct.
    Jim Dawson
    Sandy, Oregon, USA
  1. help Fusion 360
    By thiagocnc in forum Autodesk CAM
    Last Post: 01-06-2021, 09:00 PM
  2. FUSION-360 X,Y,Z
    By gibson22 in forum Mach Software (ArtSoft software)
    Last Post: 02-03-2017, 08:09 PM
  3. Fusion 360
    By Steve Seebold in forum Tormach Personal CNC Mill
    Last Post: 11-23-2016, 09:13 PM
  4. Fusion 360
    By Profm in forum Tormach Personal CNC Mill
    Last Post: 03-03-2016, 11:26 PM
  5. 3D in Fusion 360?
    By JohnToner in forum Autodesk
    Last Post: 12-24-2014, 03:07 PM
