603,407 active members*
2,082 visitors online*
Results 1 to 10 of 10
    Nov 2006
    4
    G71 Threading for Okuma Lathe
    I am having a problem threading a 1"-8 2A thread on an Okuma lathe. The code I have right now reads:
    G71 X.915 Z-2.35 D.008H.1482 U.005 F1 J8 I-.0010 M33M73
    The threads are not being cut deep enough. I believe it has to do with the H value, but I am not familiar at all with coding for an Okuma. Any help would be greatly appreciated. Thanks.
    Dec 2003
    24260
    What control? Some okuma's had Fanuc's of different vintages.
    Al.
    Albert E.
    Nov 2006
    4
    It has an Okuma control. The number on the bottom left of the controls reads: "OSP5020L". Is that what you are looking for? If not, how would I find what you need.
    Thanks for you help.
    Apr 2006
    825
    Hi pedgette,
    In your threading program of:
    The X word is the final diameter that the tool will cut to (minor diameter for external threads, Major diameter for internal threads)
    Z word is the finish point on Z for the threading cycle.
    D word is the depth of cut (can't remember of the top of my head if it's Diameter Or Radius... not at work)
    H word is the Height from the X word to the first cut, so if you are screwcutting something soft you can specify a small H value and the first cut will be deep...
    U word is the depth of cut for the last pass... once again can't remember Diam or Rad...
    F is the Pitch of the thread, in your case 1 inch
    J is the number of divisions per F. in your example 8 pitches per inch
    (you could have programmed only the F word as F0.125)
    this is used when programming odd thread pitches such as 11.5 threads per inch... as F2 J23 which equals 23 pitches for every 2 inches of thread ie 11.5TPI.
    I word is the incremental change in radius along the length of the thread. i.e. use this to get taper out (or into) your thread. Measure the pitch diameter at each end of the thread, divide the difference by 2 and use the answer in the I word - values make the tool cut -, + values are + direction.
    M33 is a Zig-Zag infeed pattern, where the tool will move from side to side as it moves down the flank. You really need the B word specified also to get this to work well.
    B word is the included angle of the thread i.e. B60 for a UN or metric thread, B55 for a BSW thread etc...
    M73 specifies the infeed pattern but as I am not at work at the moment I can not tell you the exact infeed pattern that it is. However it is the most common infeed pattern that we use.
    Therefore if you are not getting a deep enough thread you probably need to check your X value 1st, tool offset on X 2nd or finally the threading insert itself (if you are using full form inserts).
    If you want I can scan in the infeed patterns and post them for you. Let me know.
    Hope this helps
    Regards
    Brian.
    Nov 2006
    4
    Thanks for the reply. We ended up using an offset to get the threads to look good at the end of the day. After checking the major dia. and using a pitch mic they are within spec; we are just waiting for thread gauges to come in on monday to make sure. Thanks for the reply. I'll let you guys know on monday how it checks out.
    Apr 2006
    825
    Have scanned in the manual referring to the G71 cycle.
    See attachment, if I have done it correctly that is!
    Brian.
    Attached Files Attached Files
    Apr 2006
    825
    Wink
    Hi Pedgette,
    How did the threads turn out?
    I looked up the thread specs for a 1"-8UN 2A thread out of curiosity and have realised what your problem was!
    You have programmed to the Pitch Diameter of the thread rather than the Minor Diameter of the thread!
    The specs for your thread are:
    1"-8UN Class 2A
    Major Ø0.9980" -> Ø0.9830"
    Pitch Ø0.9168" -> Ø0.9100"
    Minor Ø0.8446" -> Ø0.8288"
    Thus you should have programmed an X value of between 0.8446 and 0.8288
    :cheers:
    Brian.
    Nov 2018
    Re: G71 Threading for Okuma Lathe
    Hi its our first time to do square thread machining in our cnc genos machine i need some inputs on what G codes to use and the format of the program and what the toolings can be use in diss process
    Feb 2006
    1792
    You should have started a new thread.
    If it is Fanuc, you may use G76, with zero thread angle (P----00)
    Apr 2020
    Quote Originally Posted by broby View Post
    Brian.
    Hi Sir.
    Can you help me. How to export code thread G71 from MASTERCAM?
  1. Threading with the lathe
    By two4tom in forum LinuxCNC (formerly EMC2)
    Last Post: 09-01-2013, 04:16 PM
  2. Okuma LC-20 Threading problem
    By Gunner in forum DNC Problems and Solutions
    Last Post: 12-14-2011, 05:11 AM
  3. Cross Threading on Okuma Lathe
    By montie in forum Okuma
    Last Post: 07-11-2011, 05:09 PM
  4. CNC Lathe for threading
    By ali97 in forum Benchtop Machines
    Last Post: 07-21-2009, 03:14 AM
  5. CNC Lathe Threading
    By lathe guy in forum MetalWork Discussion
    Last Post: 03-19-2007, 11:21 AM
