603,978 active members*
2,082 visitors online*
Results 1 to 5 of 5
    Jan 2007
    3
    G76 Parameter setting
    Good Day,
    Any help is appreciated......I have a Kiwa Mill with a Fanuc 10m control.
    The entire parameter settings had to be restored recently and everything works fine except the G76 Fine Boring Cycle. It will feed down, do the oriented spindle stop, and at that point it should retract in the X- direction via a Q command in the part program. This is set to work in this manner from paramater settings at 6200 and 6240. Parameter 6240 selects the direction. The retract at the bottom of the bore will only move in the X positive, and it used to move in the - because all of the part programs are programmed that way.
    Again any help is appreciated!!
    T.Gorrell
    Jan 2006
    4396
    http://www.fanucamerica.com/fa_home/home.asp
    Or someone here like Al_The_Man knows. I'd try Fanuc first to see what they have to say about this.
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
    Dec 2003
    24260
    It should be settable by those two parameters, do you have #2 set right in 6200? (xxxxx?xx).
    Al.
    Albert E.
    Jan 2007
    3
    Hello,
    Thanks for the reply.
    I have parameter 6200 all bits to 0. From what I gathered from the Fanuc book, bit #2 must be set to zero so the tool retract can be specified by a "Q" in the part program. That is working, but what are the correct values for X Y and Z in parameter 6240? The book does not specify. Currently I have X set to -2, Y is set to 1 and Z is set to 1. I have tried to change the sign on the X and it will not retract at all. Is there a correct setting for 6240??
    Thanks.
    Trevor Gorrell
    Mar 2005
    988
    I know on other version controls, the parameter for G76 "Q" has two bits to set for direction. The different combination of these bits will tell the machine to move X "- or +", or Y "- or +". But if you parameter book doesn't show the different settings.......hmmmm.... someone should know the 10 model.... Al ??
    It's just a part..... cutter still goes round and round....
  1. Set parameter from program....?
    By REVCAM_Bob in forum Fanuc
    Last Post: 01-10-2015, 11:39 PM
  2. Replies: 16
    Last Post: 10-11-2010, 01:02 AM
  3. 0TC parameter for more memory?
    By jani in forum Fanuc
    Last Post: 01-16-2010, 11:44 PM
  4. Fanuc parameter 901
    By mistux in forum Fanuc
    Last Post: 12-04-2009, 06:28 PM
  5. Replies: 1
    Last Post: 10-30-2005, 09:38 PM
