603,397 active members*
1,830 visitors online*
    Jul 2010
    174
    G76 Thread Cycle
    Let's say I have the following:
    G76 P020060 Q20 R0.
    G76 X1.6398 Z-2.275 P511 Q120 F.083333
    For Q20, P511, and Q120 do I just multiply by .0001 to get the real values?
    So: The first Q = .002, the P = .0511, the second Q = .012???
    How 'bout this.....
    G76 P011060 Q004 R0.002
    G76 X2.8978 Z-1.6 R0 P0511 Q0210 F.083333
    So: The first Q = .0004, the P = .0511, the second Q = .021???
    Do I have this right in both cases???
    Thank you.
    Jun 2003
    205
    Decimal point placement
    The decimal, when the coordinate is read by the CNC, is placed (4) places from the right ... assuming your machine is in inches. If metric ... three places from the right.
    Some inch examples :
    1 = .0001
    20 = .0020
    123456 = 12.3456
    21 = .0021
    Your example is a Fanuc program ... just FYI, some machines will read the value of say X1 as X 1.0000" ... but most Fanuc machines are set up so that X1 actually means X.0001".
    Hope this helps ....
    Bluechip
    Real World Machine Shop Software at ... Kentech Inc. - Real World Machine Shop Software
    Jul 2010
    174
    Thanks much BlueChip. Appreciate it.
  1. g76 thread cycle for dummies 20i fanuc
    By avccrml in forum G-Code Programing
    Last Post: 07-24-2018, 02:08 PM
  2. g76 thread cycle
    By warcnc in forum G-Code Programing
    Last Post: 02-03-2013, 11:32 PM
  3. G76 Thread cycle Haas SL-30
    By haaszard ahead in forum G-Code Programing
    Last Post: 12-14-2012, 03:26 AM
  4. Mazatrol T Plus thread cycle in synch?
    By Castle1 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-26-2007, 04:22 AM
  5. Programming thread mill cycle
    By squirrelledm in forum MetalWork Discussion
    Last Post: 08-08-2006, 12:31 PM
