587,833 active members*
3,702 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > G77 Circular Pocket
Results 1 to 4 of 4
    Feb 2007
    514
    G77 Circular Pocket
    Is G77 Circular Pocket somewhere in BobCad?
    John
    Oct 2005
    859
    Gcode routines can be in posts or in scripts added to those posts. You should look for specific scripts or posts to determine this.
    Look in the NC cyle or macro menus. If they aren't there then they can be added.
    Feb 2007
    514
    Nothing in the NC Cycle or Macro Menu to do a G77. How do I add it?
    John
    Oct 2005
    859
    First off if you refer to the other post you will see the info on creating a script. That includes having Bobcad modify your post (for free) to add this option.
    If you create your own scripts then you add those to the menus by using the 'Setup' menu on the NC side. You can add menus to the NC window and have them connected to your script (change the blank line inthe setup window to get your new menu item to show). You can even modify the Bobcad CAD menus but be carefull not to get them screwed up.
  1. Non-Circular Gears
    By CLyon in forum Mechanical Calculations/Engineering Design
    Last Post: 12-15-2012, 12:22 AM
  2. G12/G13 Circular pocket help needed
    By NeoMoses in forum G-Code Programing
    Last Post: 07-02-2012, 07:43 PM
  3. Circular Cut
    By Sanghera in forum Uncategorised CAM Discussion
    Last Post: 11-13-2006, 05:26 PM
  4. Circular Milling - G12/G13
    By HPT in forum Servo Motors / Drives
    Last Post: 05-14-2006, 07:22 PM
  5. non-circular CNC turning.
    By oldguy in forum Uncategorised MetalWorking Machines
    Last Post: 04-22-2004, 02:52 AM
