603,899 active members*
2,627 visitors online*
Results 1 to 8 of 8
    Sep 2005
    280
    G83 cycle on mori SL-15
    Machine won't run a G83 unless you swicth to a G17 XY plane? this is a fanuc 10T control, also cant find I.D./O.D. swicth? always had a keyed switch, found dry run and others in the settings screen but no clamp direction? were can I find manuals for this machine?
    Jun 2009
    28
    Quote Originally Posted by positiverake View Post
    If you're drilling on the face it should be a G18 for the G83, if you're drilling from the side I believe it's a G19 and a G87 instead of a G83. The O.D./I.D. chucking selection will be selected in the custom page.
    Sep 2005
    280
    mori SL15
    Thanks for the reply, this is a 2 axis lathe with no live tooling, thats why I dont know why you would have to change planes? where is the custom page? this is a fanuc 10T control.
    Nov 2006
    46
    I don't beleive that G83 drilling cycle will work on a lathe.
    You need to use a Macro if you have Macro B or make a sub program to do each peck.
    You could always use G74 which is similar to G73 on a mill.
    ( example below )
    (11/16 HSS DRILL)
    N280T0909
    N290G54
    N300G97
    N310S499M3
    N320M8
    N330G0X0.0Z.05 ( position to material center, and .050 from face )
    N340G74Z-1.060K.185F.006 ( Z is depth of drilled hole, K is the peck, F is feed per rev. )
    N350G0Z1.
    N360G0Z3.
    N370M9
    As far as ID OD chucking, I think that is located under the PC/NC button on the bottom right of the keypad.
    At least that is where it is on our Mori SL20 with Fanuc 10T.
    Sep 2009
    5
    Since it is 2-Axis Lathe so there is only XZ plane by default.You can not change/choose any other plane.Programming shold be like below.
    N100 G95 G97 S800 F 0.1 M03
    N110 G00 X0.0 Z2.0
    N120 G83 X0.0 Z-85.6 R5.0 Q10.0 K01 F0.08 S700
    N130 G80
    In a 2-Axis lathe drilling can be done at hte cetre of Job only hense value for X is always Zero.
    Z :- Depth of hole
    Q :- Packing Depth
    K :- No. of repeat
    F :- feed in mm/rev.
    S :- R P M
    Regards
    jitendra
    Feb 2008
    586
    I agree with premier industr.
    10T is usually set up with no G81-G86, because those are mill cycles. G74 is your only choice, and not a great one at that. It pecks (G74, either one or two line command), but doesn't retract fully each peck. Macro for that.
    Sep 2005
    280
    G83 cycle
    Thanks for the replys, this machine has a G83 cycle but you have to change to a G17 plane to use it, I dont like to change planes on a 2 axis lathe, maybe some one turned on a option? it even shows it in the setting page, you know were you can change the return amount in the G83 cycle. anyway im going to use a macro for the drilling, Ill look for the ID/OD button on the key pad. thanks again
    Feb 2008
    586
    On a mill I used to run, G83 had a parameter for "Z is only drilling axis" or "all axes may be drilling axes. Don't know if your control covers this, but I'd check it out.
  1. TAPPING CYCLE G84
    By Mori in forum G-Code Programing
    Last Post: 03-26-2022, 12:11 AM
  2. How to Repeat in G81-cycle with G91
    By brinchen in forum Okuma
    Last Post: 03-06-2009, 03:38 AM
  3. G76 CYCLE
    By BAD DOG in forum Uncategorised MetalWorking Machines
    Last Post: 09-20-2008, 10:33 PM
  4. G76 Boring Cycle
    By Gorrell in forum G-Code Programing
    Last Post: 01-25-2007, 10:22 PM
  5. G68 + Rectangle Cycle
    By Shizzlemah in forum Fadal
    Last Post: 01-26-2006, 11:17 PM
