603,335 active members*
3,321 visitors online*
    Jan 2005
    49
    G83/G87 parameters
    Hi all I have a question about the parameters more for the G87 pertaining to how far the drill will stop short in the peck drill cycle , off the top of my head parameter #5114 is for the G83 peck cycle to stop short of the last drill depth in the cycle and I have it set at 1000 which is actually .100 is there a parameter to set so the G87 cycle will stop short that distance , right now it stops short .200 and I would like to tighten it up by .100 , this is a Doosan SLY machine with a Fanuc 18i controller. We use the G87 cycle for drilling holes on the O.D. of the part with live tooling . I have a hunch that the parameter used for the G83 cycle is shared with the G87 maybe ? Any help I would thank you all .
    Jul 2003
    263
    Quote Originally Posted by DocHod View Post
    you have to remember that the X axis on the lathe is diametrical not radial so the machine actually doubles the value in parameter #5114 for all X axis work i had the same problem when i first started using the live tooling. i usually program an R value which the machine reads as incremental.
    If you can ENVISION it I can make it
    Jan 2005
    49
    thanks King , it does make scence.
  1. Help Need YAM CK2 Parameters
    By bertcnc in forum Fanuc
    Last Post: 03-02-2020, 02:57 PM
  2. OKK Parameters lost!!!!
    By Fidelity_Mold in forum Uncategorised MetalWorking Machines
    Last Post: 08-01-2007, 08:20 PM
  3. parameters for G71
    By harrascustom in forum G-Code Programing
    Last Post: 04-09-2007, 04:06 PM
  4. parameters
    By mikeh78 in forum Haas Mills
    Last Post: 05-03-2006, 03:20 AM
  5. Parameters
    By Vince.P in forum DNC Problems and Solutions
    Last Post: 04-28-2005, 01:06 AM
