I don't know if soft jaws even exist for this lathe, but I was doing some searching around and could not find anything.
So, I figured I would attempt to make my own soft jaws.
How? Well, here's what I was thinking about doing...
The jaws on my 4" chuck aren't exactly running true. I have contacted LMS and requested a replacement, but that's still not good enough for me. I want to make sure that my jaws are running as true as possible to my lathe. I was planning on taking some scrap aluminum I had laying around and making my own soft jaws to fit my chuck. The original jaws on the chuck do have enough room for a couple of holes to be drilled and tapped for two bolts. All I really have to do is take some measurements on the original jaws so that the aluminum jaws fit the "steps" in the original jaws. After the aluminum jaws have been measured and milled at an angle, I can take them to the lathe, attach them and cut them to have a small curvature to clamp them to work pieces. I can also cut outside jaws on them as well if I wanted to use them for pipes.
Has anyone else attempted this? I figured this would be a good "starter" project for me. I just have to make sure that the holes I drill don't go too far. The only problem I may face is that the original jaws are made from harder material and I may have some problems drilling into them. I haven't attempted this yet, but I don't see too many issues, unless I am overlooking something obvious...
