587,753 active members*
3,113 visitors online*
Thread: G92
Page 1 of 2 12
Results 1 to 20 of 36
    Jul 2006
    50
    G92
    Can anyone tell me what this is for?
    Jul 2005
    12177
    Quote Originally Posted by jybute
    Did you read the Haas manual?
    " A G92 command effectively shifts all work coordinate systems so that the command position becomes the current position in the active work system."
    I think this is correct:
    It allows you to create extra work coordinate systems by creating values in a G92 register. These values are then added into all the positioning calculations that the machine does. Imagine that you are using G54 and your G54 coordinates are X-8.0 Y-6.0 and you move the machine to G54 X2.0 Y2.0; this means in the machine coordinate system you are at X-6.0 Y-4.0. Now you do the G92 command G92 X-4.0 Y-4.0; the machine does not move but a value is entered into the G92 register so that when you command the machine to go to G54 X-4.0 Y-4.0 it does not move because you have made your exisiting position this position. And if you now command G54 X2.0 Y2.0 (which is how you got to that position) you will move to a new position.
    Are you confused? Do you know where the machine is going to go whenever you now give it a motion command. If your first answer was 'Yes' and your second answer was 'No' I think you are in the same shape as most people trying to sort out G92.
    Anything that can be done with G92 can be done in a less confusing manner using G52 and I will be surprised if anyone advises you to try and understand and use G92.
    Apr 2003
    1873
    You can find a ton of stuff on G92 just by doing a Google search.
    Here is a link to an excellent explanation and example.
    http://www.cncezpro.com/g92m.cfm
    Mar 2003
    4826
    I agree with Geof that no one would recommend using G92 anymore, but who knows, there might be the odd valid use.
    I like to keep the explanation as simple as possible: the G53 coordinate system is your machine's 'real coordinate system' that is established after it homes all the axis. When homing is completed, stored parameters set the G53 axis displays to certain values, lets say all zeros for that machine home position.
    G92 is like a superficial renaming of the G53 coordinate system, kind of like 'programming the axis displays' to read whatever you want them to read. This is why it affects all the work offsets the same amount.
    While it sounds handy, this can lead you to completely loose track of where machine home is, because you cannot cancel a G92 command, you can only issue a new one, and hopefully, if you have successfully returned to an accurate known position, then you can rename it correctly so that the axis displays once again correspond to distances from home in the G53 coordinate system.
    That is how it used to be in the old cnc's anyway. The imminent danger was that if the control ever read a G92 command when it was not located at the start position of the program, you can imagine how it would assume the current position was the starting point and start machining whatever happened to be located in that area. Yikes! When using G92 and doing a program restart, you must positively move to the correct start point before that G92 is read, that was the rule.
    On a modern machining center, you can likely recover position by homing all the axis again, and finding your way over to the G92 start position after the crash . Not fun, and I suspect that is why work offsets were created, because the machine coordinate system stays intact.
    First you get good, then you get fast. Then grouchiness sets in.
    Jun 2003
    2103
    Hu at present I am that odd valid case. While I don't use what most would consider a commercial controller I do have to use G92 on may of my programs.
    The thing that bothers me about it is that it is persistant and if you fail to cancel it with a G92.1 you are in deep voodoo!
    Mike
    No greater love can a man have than this, that he give his life for a friend.
    Jan 2006
    4396
    G92 is still used
    G92 is still widely used in shops in Large Aerospace Machine Shops in this area. Only reason is that the original programmers years ago programmed that way, and no one has time or they are too lazy to change them.
    Also Fight Safety Certified Companies have to document all procedures in machining completely including programs for CNC's. If they reprogram a job or part they have to get that specific program authorized by the auditor along with all the processes after. Sounds stupid I agree, but when you go through the certification process and have a 40 million dollar contract companies tend to play by the rules for Flight Safety Parts.
    Personally I have only used G92 once. The reason was that a customer wanted our shop to make his parts using his program and material. The customer was paying a lot so the boss didn't care. On the other hand if we programmed regular jobs with a G92 the boss may have blown his stack because he didn't want the programs written that way. The specific orders from the boss where G54-G59 and all programs where to be written in Absolute with no Sub-Programms. What a pain. The joke going around in that shop was "The next thing he will want us to do is to stop using Canned Cycles".
    As long as that function is still available in Machine Tool Controls someone in the machining world will have a specific reason for using it.
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
    Jul 2006
    50
    Thanks, guys. I guess my real question was, whay woould anyuone want to use it? We use VGibbs, with several different post files, and we lost a pretty pricey part the other night, cause the wrong post was used. I have never had a problem with G92 when 3axis milling, but when rotary milling, or even rotary positioning, the issue has come up. We actually use a post that has in the title, "noG92". The post files are still a bit of a mystery to me also. Ive just learned wich side of the computer to sit on. But Im slowly bringing it together.
    Thanks again guys.
    Jun 2006
    478
    We actually have a machine, 1978 Mazak V-12 with a 6m Fanuc control and as far as I know G92 is the only coordinate system we can use on it. What we do is determine how far from machine zero is our work zero, i.e. x-20. y-10. z-15 this would be from machine zero to wpc zero. Next, in the prog., the machine is sent home via G91 G28 X0 Y0 Z0. After homing the mach. the G92 line is used like this:
    G91 G28 X0 Y0 Z0
    G90 G92 X20. Y10. Z15.
    T?M6
    G90 G0 X0 Y0 (MOVE MACH TO WPC ZERO)
    G43 H? Z1. (MOVE MACH TO Z1. USING TOOL LENGHT COMP.)
    ETC.
    ETC.
    M30
    Note that the axis is "set" at the distance from the work piece to the current position.
    It's quite simple really, although primative!
    A.J.L.
    Jul 2006
    50
    Here is an example of the problem.
    N22 G0 X-.4 Y0. A228.277
    N23 Z1.875
    N24 G1 Z1.5425 F18.362
    N25 M97 P237
    N26 G0 X-.4 A228.277
    N27 Z1.6825
    N28 G1 Z1.35 F18.362
    N29 M97 P237
    -N30 G92 A-131.723
    note the absolute "A" moves then the G92
    After running the code in the m/c the "A" pos. is @20000.00 deg.
    So when it starts to cut in the next op, it is in the wrong "A"pos.
    Mar 2003
    4826
    Could it be a simple typo? Using a G91 incremental movement (which would produce an actual rotation, whereas G92 would not) would be reasonably common practice. Depends on the part, I guess, but the same rule would still apply: at some point the rotary must be returned to a known position in G53 (where you can safely branch out to work offsets), and it would be next to impossible except for homing it again.
    If an actual program would be more conveniently run with a shift in A, then a new work offset should be called, with the appropriate A amount, all the other XYZ being copied from the original work offset.
    Jun 2006
    478
    N23 Z1.875
    N25 M97 P237
    N27 Z1.6825
    N29 M97 P237
    -N30 G92 A-131.723
    If the above is read by the control it would have posistioned A axis at 228.277 in absolute, assume. The G92 command would then " set " A axis at -131.723. So in other words instead of being at A228.277 it would now be at A-131.723 but no axis movement would have occured
    Jul 2006
    50
    Quote Originally Posted by ajl6549
    It actually rotates the"A" in the sub. So when it comes out of the sub, its going to index to the wrong "A".
    Jun 2006
    478
    It will index to the wrong place because G92 is "setting" it at the wrong place. (chair) It looks to me that you shouldn't be using G92 at all at that point in the prog. Are you shur your post is correct? or is G92 a typo?
    Jun 2006
    478
    I just wanted to try some of those little animations, no ill intened
    Jul 2006
    50
    this is a problem that the post file puts out. I have no control over what it puts out, I just press "post out" in the VGibbs software, and let the computer take care of everything. But we started having problems with the G92, so we got another post that wont put them in there. Im just trying to understand what the purpose of G92 is, and it seems to me that it doesnt serve any useful purpose on the m/c's that we have.
    Jun 2006
    478
    Well like I said G92 is a type of coordinate system, typicaly used on older machines before the "wide spread" use of G54 - G59. I'd say your post is still messed up if it spits out G92's and you don't need them. Or maybe somthing in "Vgibbs" is telling it to use G92 as a default perhaps.
  17. #17
    Jan 2006
    4396
    I've never used G92 for 4th axis indexing, but the G92 as per Yasnac and Fanuc (never used G92 with a HAAS) the calls once in the begining of the Program and never called again. The Yasnac Control MX2 the G92 is set in MDI if you are going to use G54-59.
    Ex. Send all XYZ Positions Home switch to MDI then Input G92X0Y0Z0 then hit cycle start. After setting G92 in MDI, G54-59 are the only WPC's you can use and have to be input in the parameters without decimals for XYZA. If G92 is called in a Program you will have a Big Boo Boo to fix.
    HAAS may or may not be the same to a degree.
    Ex.
    O00001
    G0G17G40G49G80G90G98M5
    G91G28X0Y0Z0M9
    G92X??.????Y??.????Z??.????A??.????(G92 is set to the Machine Position)
    T1M6
    G90G43G0H01X?Y?Z?S5000M3
    Why not setup VGibbs to post the program using a different WPC like G54-59?
    The last time I worked with a Haas it was a VF-3 and had an array of Work Position Cooridinates.
    Your best bet would be to get Haas on the phone or checkout their Website as I think they have a user Forum and information on specific control versions.
    Also call VGibbs and tell them of your G-Code posting problem with G92. The Posting Parameters of VGibbs shouldn't be that difficult to change.
    Toby D.
    Schwarzwald
  18. #18
    Jul 2005
    12177
    .... Im just trying to understand what the purpose of G92 is......
    I am reminded of a Charlie Brown cartoon, I forget the details, which ends with Lucy telling Charlie Brown that enduring some misfortune was for the good of his soul. I think G92 has a similar purpose; if you remain sane after trying to use it you have a very strong mind.
  19. #19
    Nov 2003
    126
    I use G92 quite often in A axis rotary operations.
    Some spirals in the A/X can end up with the A axis in the 20k's of degrees or more. Then to re-run the program for the next part, It needs the A axis at 0. I will edit the code at the end of the program so that the axis rolls to the nearest position divisible by 360, and then issue a "G92 A0". I run many parts like this, so issuing a "G5x" to offset the A axis is not really a solution.
    Is there any other way, other than commanding the A axis all the way back to 0deg and wait for it to "unroll"?
  20. #20
    Mar 2005
    1498
    060730-0625 EST USA
    nicad:
    Can you use
    G53 A0
Page 1 of 2 12
