Originally Posted by
Alex S.A
The CNC used is one model Vision Le from ESAB.
I getting the feeling I know this machine much too well
As murphy says it may be an offset or null adjustment, but what you have to do is remove the analogue input to the drive and jumper the input terminals and see if the drift is caused internally by the drive i.e if the drive offset is out, or if the command D to A output needs to be nulled, some controls have a controller analogue null adjust. Which is adjusted by commanding a zero move with the motor drive disabled so it cannot move and check to see if there is 0v on the analogue output.
Al.
Albert E.
