587,158 active members*
3,061 visitors online*
Page 2 of 2 12
Results 21 to 26 of 26
  1. #21
    Jan 2008
    1538
    Re: Gantry mill with moving gantry for Z-axis
    https://www.vulcanmachineco.com/
    This company is developing a mill with a rising gantry and it looks like single central screw.
    They have some YouTube videos that show it
  2. #22
    Jul 2018
    6457
    Hi Pippin - Good find. I think this config makes so much sense! Now to do it in Tetrium....cheers Peter
  3. #23
    Jul 2018
    6457
    Vulcan mechanics renders - Peter
  4. #24
    May 2011
    790
    Yeah, that's the way to do it. Looks like that machine is well thought out. I wonder how much they will sell for?
    It only has travels of 13" x 13" on X and Y. 12" x 24" would be so much better IMO. But it's really nice that it can fit through a standard door opening. I wonder at what width it would need a second screw to prevent racking with the given bearing spacing.
    Since the table can't actually pass beneath the columns, I still consider this to be a single column design. But really nice find of a rising gantry. I could see these becoming quite popular. Thanks for sharing.
  5. #25
    Jul 2018
    6457
    hi Nic - The first batch is at $7000USD can see them making much -$$$ from that., Then they are going to set a new price. I looked at some of their videos. Initially they had the table go thru the columns as you would expect but they changed that along the way. The working envelope is small for the config. A mill such as attached can get 330x330x355mm easily and is cheaper. They have some sorting out to do I expect. Peter
    wracking should be prevented by the bearing system not the drive system.
  6. #26
    May 2005
    1662
    Quote Originally Posted by NIC 77 View Post
    Yes, that seems like an unnecessary limitation. The machine is well thought out otherwise so I must be missing something.
    edit/ It also looks like the table could be wider (y direction) with no real downside.
    Anyone who says "It only goes together one way" has no imagination.
Page 2 of 2 12
  1. Fixed gantry vs moving gantry
    By scott0999 in forum DIY CNC Router Table Machines
    Last Post: 01-31-2014, 06:14 AM
  2. 2nd Build - Steel Tube, Moving Gantry Style, Mill / Router
    By InventIt in forum Vertical Mill, Lathe Project Log
    Last Post: 02-26-2012, 08:15 AM
  3. Trade offs between Moving Gantry and Moving Table
    By gregmary in forum DIY CNC Router Table Machines
    Last Post: 04-22-2011, 07:48 PM
  4. Gantry: planning to design moving open gantry
    By rdcd in forum Mechanical Calculations/Engineering Design
    Last Post: 11-14-2009, 10:52 PM
  5. Moving Table vs Moving Gantry; Dremel vs Router
    By chuckknigh in forum DIY CNC Router Table Machines
    Last Post: 03-28-2007, 02:48 AM
