Hi guys,
I am totally new in this cnc'ing. But I am very interesed to build one to make my life easier when I need it to cut some alluminum, pcb, wood or plastic.
My goal is to have a travel of 6" x 12". The Z axis will be mounted on the Y-axis (Is this correct??)
I found a local supplier who can supply me a round rod, linear bearing and the bearing mounting at a reasonable price.
The company is http://www.soonfar.com.my/prod_su.php
I plan to use a 16mm rod 2 in parallel on each axis.(Is this strong enough)
I see alot of people using the linear slide. But I think it is too expensive for me.
I appreciate all the replys from you guys.
